Question about Lexmark X Office Equipment & Supplies
Carrier jam how do i clear the carrier
Posted by Irma Donovan on
5 Related Answers
Anonymous
SOURCE: clear carrier jam
There are few things you may try to fix the above problem.
Rebrick the printer. and set the printer to factory defaults
Posted on Apr 20, 2008
proton77
Mandeep Singh
  • 1183 Answers
hi,
Follow the wizard on the following website , to help you to pinpoint the problem
http://tinyurl.com/3nh59x
Thanks
Proton
Posted on Oct 02, 2008
Anonymous
  • 69 Answers
SOURCE: CLEAR THE CARRIER
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 06, 2008
Anonymous
  • 446 Answers
SOURCE: How to clear carrier jam in Dell Photo All in One 944
simply open up your printer and see if there is any residual paper that get stuck, in some case if you can find some small miniature piece of sensor it might cause a erratic sensing that there is a presence of paper while there isnt, try to clear this or clean.
paper jamming indicator means there is some paper in the paper path, unless otherwise ou clear this up you cannnot print.
after you may need to power down or restart your printer once again
cheers
Posted on Nov 27, 2008
Anonymous
SOURCE: Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Posted on Jan 17, 2009
How do I set the margins on a Smith Corona Wordsmith typewriter?
OTHER FEATURES Tab
To set a tab, move the carrier to the desired position and press the key. To clear a tab, move the carrier to the tab position to be cleared and press
the + key.
To clear all tab position, press the + key for half a second.
Centering
Your typewriter allows you to automatically center a line. 1) Press the + (CENTER) key.
The carrier will move to the center position between the left and right margins. 2) Type the text. The carrier will be backspaced half a space.
CODE
3) To print the text, press the ,
4) To cancel centering mode. press the
to the center position.
Decimal Tab
Decimal tab allows you to align numbers by decimal point at the tab position. 1) Press the + key.
The carrier will move to the next tab position.
2) Type the text. The carrier will be backspaced one space.
3) When the decimal point (.) is typed, the text will be printed out with the decimal
* If you make a mistake, press the
or
key.
Pressing the + key will erase the whole line and move the carrier
point.
4) To print the text, press the ,
5) To cancel the decimal tab mode, press the
to the position where DECIMAL TAB mode is entered.
or + key. key.
+ key.
* If you make a mistake, press the or
TAB C
CODE
9
RETURN
TAB
or
key.
+ key.
CODE
DEC TAB
TAB S
CODE
TAB C
RELOC
X
CODE
WORD
CODE
WORD
CODE
DEC TAB
RETURN
X
TAB
CODE
DEC TAB
RELOC
CODE
WORD
CODE
WORD
11-10-
Oct 02, 2018 | Smith Corona Office Equipment & Supplies
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Pink ink cartridge leaked and all pictures now come out red
It sounds like you have clogged some of the nozzles with the pink ink. To clear this remove all the cartridges, remove the printhead (rock the internal cartridge carrier by pressing the carrier end nearest you. This should allow you to remove the carrier). Put some warm (not hot) distilled water in a bowl and soak the carrier overnight. Remove the carrier and carefully dry off the printhead. The printhead needs to sit for a couple of hours to completely dry before inserting the carrier and ink cartridges. This should clear your problem.
Let me know if you have any other problems. Thanks.
Dec 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I changed the ink cartridges and now it just flashes and says clear the carrier jam and press start??? what is a carrier jam and i have cleared everything that can be cleared and it still want work, so...
The mechanism that carries the cartridges is call the carriage (carrier). Remove all the cartridges and reinstall them, now move the whole mechanism with the cartridges installed from it's original position to somewhere and verify that there's no obstructions blocking the movement of the carriage. You can simply open the front access door and move the cartridges to somewhere from where it is now. That'll help you clear the error if there's no physical damage with the machine.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 30, 2010 | Dell 924 All-in-One InkJet Printer
Carrier error 41, 44
hi google carrier error , not sure but it could be pressure switch , but it is on google
Jun 21, 2010 | Heating & Cooling
Dellv305 printer, clear carrier jam. My son pulled the paper out from the bottom of printer. How do i clear carrier jam?
Please perform the steps mentioned in the link below:
Paper Jam
The steps would help resolve the carriage problem as well.
Jun 17, 2010 | Dell 926 All-In-One InkJet Printer
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Clear carrier jam
hi,
Thanks
Proton
Oct 02, 2008 | Dell 924 All-in-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
