Lexmark X3470 All-In-One InkJet Printer Logo
Posted on Jul 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer displays "cover open" but it isnt. printer will not do anything
Anonymous
Level 2:
  • Expert 79 Answers
  • Posted on Jul 04, 2009
Anonymous
Expert
Level 2:
Answers
79
Questions
0
Helped
19981
Points
211
Try to of the power and din open all parts the printer and din close again after that on again did you try it
2 Related Answers
Kindofcheap
Jayson Brollini
  • 241 Answers
  • Posted on Sep 26, 2008
SOURCE: My printer
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate my solution
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Anonymous
  • 53 Answers
  • Posted on May 27, 2010
SOURCE: Error message cover open and it isnt
Reinsert your cartridges after properly cleaning them
Ir 2020 e805
E805- Fan Failure- open rear cover find PSU and check for rotation of cooling fan at power up ( spins as soon as display lights up)
If it isnt spinning - replace with correct part from Canon, the circuit is expecting a feed back specific value which will only be seen with the correct fan.
Canon Fax-L350 display check printer Alarm red "could
Open the main cover. Look into the body of the machine. The covers top left corner has a projection that when the lid is closed this projection passes through a hole in the main body and hits a micro switch to say the cover is closed. the switch has stuck. Poke a thin screwdriver (power off of course) and watch the switch pop back into its right position. All will be well. A well known fault of this model.
My printer is not printing anything. the status light isnt even on what should i do?
Does the "Status Monitor" in your printer display any errors?
Is the printer cover securely closed?
Is any of the LEDs in the printer flashing?
What happened just before the printer stopped working? Did you have a poer failure? Did you install new software or hardware or a Windows update?
Please, report back the status (ON, OFF, BLINKING) of the following LEDs:
TONER
DRUM
PAPER
STATUS
1helpful
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
5helpful
Lexmark x3470 has cover open in display will not do anything now
you need to open cover and undo and remove the grey cover inside the printer as there is a switch at back of machine which has *** off
My printer is saying the cover is open but it is not. I have opened it and closed it a few times but it isnt doing anything.
Thank You
Jayson
2answers
Cover open message
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Lexmark x3470
Hi, can you help me? This printer1.gif was working fine for about 4 months and then in wont print anything anoymore. All it says to do is close the lid, but the dam thing isnt open. I tried opening and closing, removing ink4.gif cartrige and even slamming it down but still say door opened?
14helpful
5answers
Printer trouble
Find this in the web
http://h10025.www1.hp.com/ewfrf/wc/document?cc=hk&docname=c00489814&dlc=en&lc=en&jumpid=reg_R1002_HKEN
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
