Question about Xerox CopyCentre C20 Black and White Copier
Xerox c20 copying only middle of page
Copier only copying the middle of the page or none of the page just black line down the center of the paper
5 Related Answers
Ronald Nathan
  • 12 Answers
SOURCE: xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Posted on Jan 27, 2007
Rick Kasper
  • 2072 Answers
SOURCE: Xerox copycentre c20 paper jam in 2 how do i get it out please
Unplug the machine, open the right door. Get a phillips screwdriver.
Look on the upper portion of the paper path, you will see an assembly with yellow waning stickers that say HOT. There are 4 silver screws on that fuser assembly. Remove those screws, and unplug the white connector. Pull back toward yourself to remove the fuser.
Lay it down and remove 2 silver phillips screws , it will open up and you can remove the paper. Make sure the machine has been off for a half an hour or so, It is hot. Take a good look at the black aluminum coated roller on top. See if it looks smooth and clean, If it has a lot of toner built up on it, you will have to repalce the fuser or it will continue to jam and give you ghost ( light reprinted) images up and down your page.
Also the M20 does not handle large black ares on a page such as a picture or magasing cover being copied. Largs solid areas tend to stick to that heat roller. If you do copy a photo, try and allow about 2 inches on the top of white. Just move your original down on the glass about 2 inches from the edge. 2 inches to tie right of the edge of the glass.
Posted on Jan 18, 2009
Anonymous
  • 67 Answers
SOURCE: Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Posted on Apr 16, 2009
Everett Lin
  • 990 Answers
SOURCE: CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Posted on Jun 05, 2009
Anonymous
  • 136 Answers
SOURCE: Xerox 3001 Copier. I installed new toner and the
Also I would wait until it stops first, then installed the paper, wait until it feeds through then see if you have the sa problem.
When new toner installs I always recommend to customers to wait for the cycle to complete ,then try it again. See if tht helps
Posted on Dec 07, 2009
Unlock my Copy center C20
check under the screen and above outputtray (Ceiling) there's a slide which probably is in the wrong position
Nov 11, 2013 | Xerox CopyCentre C20 Black and White...
Xerox Copier C20
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 09, 2008 | Xerox CopyCentre C20 Black and White...
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
My Xerox CopyCentre C20 doesn't always print the entire page, as if it is only scanning part of the page. It happens when the original is placed on the glass surface as well as when the original is sent...
the paper size detector may not detect the original size of the document check the paper tray indicator light on the panel and make sure the direction is the same with the original document onthe glass
Aug 26, 2010 | Xerox CopyCentre C20 Black and White...
When I use the automatic document feeder on my xerox copycentre C20 I get a black line running the length of the page. If I make a copy from the glass, one sheet at a time, it is fine. Is there a way to...
You have something on your "**** glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
(Please rate this response as I'm trying to obtain the next level.)
Aug 04, 2009 | Xerox CopyCentre C20 Black and White...
Jun 05, 2009 | Xerox CopyCentre C20 Black and White...
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Jan 18, 2009 | Xerox CopyCentre C20 Black and White...
Xerox Copier Model XC1020
if the paper is black and the copies are coming out there is a problem with
1) the drum,
2) the transfer unit--- the unit under the drum, with thin wires,
Jan 08, 2009 | Xerox CopyCentre C20 Black and White...
Blank copies down the centre of the page
pls check the drum charge grid and toner cardritge. may be the toner is empty or charge and transfer corona wire getin dust.
Jul 23, 2008 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C20 Black and White Copier Logo
107 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
