Question about Generac Power Systems Electrical Supplies
My generac 12000 watt generator has no spark,i replaced the plugs but still none,any advice would be great.
Posted by kevin walt on
Kelly
    Sergeant:
  • 224 Answers
It sounds like the coil has went bad, replace the coil and you should be good to go
Posted on Oct 06, 2014
Testimonial: "I did figure out that there is a little spark but its not very good could the flywheel and coil have some rust on them ?"
  • 2 more comments
  • kevin walt
    kevin walt Oct 07, 2014
    the generator will run but starts real hard,and sometimes it wont even start
  • Kelly Oct 07, 2014
    Rust on the coil and flywheel can cause a weak spark, if you can clean them up and check the gap to make sure its correct
  • kevin walt
    thats what i was wondering ,,,looks like it will be a real job to get into the flywhell and coils.thank you for advice.
    It looks harder than it really is, hope thats the only issue and you have it back up and running soon, Thank you
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Starts runs great turn off the it won't start again
    Generator runs then shuts off - YouTube
    ? 8:17
    https://www.youtube.com/watch?v=6esHkPyygWw
    Sep 6, 2011 - Uploaded by mainblind
    How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
    gasoline engine on portable generator won't start what do I ...
    answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
    Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
    How To Fix A Portable Generator That Won't Start ' My ...
    blog.mygenerator.com.au/how-to-fix-a-portable-generator/
    Jan 21, 2016 | Electrical Supplies
    I have a natural gas generac 8kw it was running fine now it will not run found that out after the last power outage pull the plug looks good found that it will not spark at the plug
    How old is it???? Does it have a read out that tells you what's wrong?????When is the last time you did a maintaince tune up on it???? Mine is fueled by propane and I changed the oil and plugs and it's been fine since....Sometimes it's the starter/ignition..I would do a complete tuneup first, then clear codes, then try starting it up manually....If that works put it back on auto..Good Luck
    Mar 01, 2015 | Generac 13,000 Watt / 13,000 Watt Home...
    Where is the spark plug on my generac xg8000?
    baried in the motor hard to get to but if you take tank off you should see it good luck
    Sep 03, 2014 | Generac 5847 XG8000E XG Series 8000 Watt...
    What's the mag or coiul on a generac 6500 generator 13 hp
    The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
    Sep 30, 2012 | Generac 6500 Watt Gasoline Generator - 49...
    Generac ix 2000 does not start. checked spark plug and it is good. oil good.
    what a **** generator, worked for 100 hours and now wont start anymore.
    did all the checks and replacing of spark plug and oil etc, simply wont start, ****, ****, ****..... service is horrible too. they just give you the runaround.
    Apr 02, 2012 | Generac Power Systems Generac 5793 Ix 2000...
    I have a Generac XL4000. It rill start but not run right.
    If the area you live in has alcohol added to their unleaded gas, then you will probably need to rekit the carbuerator. Also check the spark arrestor for plugging up. Try to find a non alcohol, off road unleaded gas for your generator.
    Jan 20, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
    12000 watt powermate won't charge the battery
    Some Coleman generators have rectifier /diode pack behind panel others have a diode inside generator cover however when diode fails it usually fries the winding. Your winding could be within the generator or under flywheel depending on model#. If your generator had a fuse to protect winding then test diode and replace as necessary. You may also just plug a small battery charger (1 or 2 amp ) into 115v plug to charge battery / power coil. Good luck and email if you have other questions.
    Oct 27, 2009 | Coleman Electrical Supplies
    I have a Generac 15000 watt portable generator. It cranks great, but will not start. The plugs are wet, doesn't seem to be getting any spark. Have replaced plugs, any suggestion.
    I have solved the flooding problem . unfortanetly you must remove the carb to fix it. once you remove the carb you need to remove the fuel bowl. In the bottem of the fuel bowl there is a electronic seloniod that controols the amount of fule going to combustion. this aria had varnish and gunk built up around the plunger of the selonoid, long story short clean this out with carb and chook cleaner and put it back together. start her up and she will run like a champ.
    Apr 05, 2009 | Generac Guardian Ultra Source 15,000 Watt...
    Electrical Supplies Logo
    158 people viewed this question
    Top Generac Power Systems Electrical Supplies Experts
    John Trevino
    scj103
    STEVE SPAM REMOVER
    Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
