SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
SOURCE: Kenmore 106.53603202 stopped cooling making a clicking sound
The compressor may not have to be changed it could be the relay that is bad, not properly starting the compressor. The relay is attached to the compressor where the wires go to it. Remove it, Shake it, If it sounds like little rocks are inside (it rattles) than it is bad. Let me know what you find
SOURCE: GE Profile Ref. Ice despenser motor does not turn. Auger turns
I had this same problem today, and after tearing apart the door and digging with the multimeter, I found that the bulb was drawing to much current {probably due to age} and that pulling it made everything else start working. The high resistance was drawing too much current from the IC on the door panel board.
I'm going to get a new bulb tomorrow, but if you yank the bulb it'll probably work. {If you have the same problem}
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
