There are two fuses 3.15A, one on the main voltage board and another on a secondary board both have blown. Can anyone offer any idea. I don't have a circuit diagram.
If the main fuse should blow up; surely there should be a short circuit to any component/s at it. If the secondary [DC] fuse also has blown up, there should be a reason for it too.
You should first check out the main power board alone, and then the secondary board connected. It will be impossible to follow these without its schematic diagram. Try to download it by internet. Without proper guidance; how can we follow the complicated circuits, and check the components?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: tv will not start after power surge
Voltage checking and caps inspection will be the first thing to do.
If you can post the pictures, that will help a lot. Look at the inverter board to see if you are getting 12~18vdc feeding it, also look for caps with leaking/bulging top.
See some pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Testimonial: "Example pictures quite helpful. I do some more visual checks and then post pictures of my power supply and ask for test locations. Thanks"
SOURCE: Mine has 7 red blinks and wont come on. i pulled
No, your done. Now replace the Y-Main, that's the large one you found the fuse blown on and replace the two buffer boards that the Y plugs into. Those are the two at the far left. The part numbers are on the boards. So that's 3 boards you will need. sometimes they sell the buffers together as a pair which is cheaper. DO NOT buy from second hand resellers. Always buy new when it comes to plasma sets.
SOURCE: ref: Philips LCD DVB 26"
You have a diode arrangement in your power supply that converts the AC power to DC power so that it can be stepped up to operate the high voltage power supply of the set. If those diodes are blown, which happens frequently in a storm, then you have no voltage to your high voltage. You are going to have to check that diode arrangement by making a continuity check both ways on each diode. A diode blocks voltage one way but lets it pass the other way, thus producing a DC voltage.
SOURCE: ref: 26" 26PF5521D model. Following
I'm afraid the electronics have been 'spiked' by the lightning. It may have affected more than one module There is little you can do other than having it looked at by a professional, however you may be able to claim on your insurance?
Regards
In most cases, if the main power supply fails, the low
voltage supply that provides enough power so the set can receive input from
your remote, also lives on to signal problems, often by flashing the power LED
in a pattern.
In your case, apparently the low voltage supply is also
dead.
This can be caused by both supplies being damaged from a
line surge caused by 'dirty' AC power, or a spike from a lightning strike
somewhere in your power network.
These spikes can travel long distance so a strike need not be
all that proximate to do damage.
If no fuse holder is found on the back of the set, it may be
necessary to remove the back panel for access.
If you choose to do this, it is safer to leave the set
unplugged overnight to allow any hazardous voltages to discharge.
Look for a separate board or an area which has larger
components in it.
These will be cylindrical cases and larger block-like parts.
If there is a user-replaceable fuse in the set at all, it
will most likely be in that area.
If this damage was caused by a high voltage spike replacing
the fuse may be fruitless and if a replaced fuse blows again, then other
circuits have been damaged and major boards will have to be replaced as well.
The cost of reviving a lightning damaged set of any kind can
often exceed the cost of replacing the whole set.
Even the most primitive plug strip contains components that
afford some protection against this kind of damage but the best protection can
be had with a 'whole house' surge suppressor.
These cost ~$200 US and feature insurance against appliance
losses up to $10,000.
They require access to the main breaker box, safety precautions and a few tools for installation.
