With a DKT 2xx0, you're probably on a DK-XX system
Try these steps
Leave phone on hook
Press REDIAL
Press SPEED DIAL
Enter Speed Dial Bin Number:
(Small system is 10-49 personal, 60-99 system-wide)
(Medium system is 10-49 personal, 600 - 699 system-wide)
(Large system is 100-139 personal, 200-999 system-wide)
Enter phone number
Press REDIAL to lock in number
If you're on a CiX system:
Press #9876
Press SPEED DIAL
Press Bin Number 100-199
Enter phone number
Press Speed Dial
Lift handset to lock in
SOURCE: how do I set up and use speed dial on a Toshiba
what system u using??
if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
- to set speed dial press REDIAL SPEED DIAL standard speed dial code 60 or 600, follow by 9+destination number, REDIAL to confirm.
- to call press speed dial + code or press * + speed dial code (*60 / *600)
- if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number #
- to dial press *200...
SOURCE: how do I set up speed dial for a Toshiba
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
SOURCE: I have Toshiba dkt2010-sd telephones and need to
it depend on the system, but usually on the main phone Ext:10 or 200 press redial then speed dial then "BIN" number ( 10-49 for user 60-99 on system dials or 600-699 for large system dials) then type the number with 9 in front if you dial that to dial out .. finish by pressing redial.
SOURCE: how can I set up
Yes you can just press park and 5 if you have programmed the number 5 as the speed dial for 105. Here is a user guide to help you with the procedures to set up the speed dial and also give you more information on your device.
http://www.atsco.info/downloads/CTX%20DKT-IP%20Handset%20User%20Guide.pdf
Hope this solution has been helpful?
Feel free to request further information
