Question about Yamaha HTR-6130 Receiver
All Yamaha HTR-6130 codes don't work on DirecTV remote
I have also tried all of the codes for the Yamaha HTR-6130 so I can control the volume with my DirecTV remote, and none of them worked. I hope there is a code out there that works.
Posted by diva2217 on
  • diva2217 Jul 05, 2009
    30176 didn't work. I tried to set it for both AV1 and AV2, and the volume control still went to the TV, not the audio receiver. Is there something else I'm missing?
Anonymous
    Sniper:
  • 50 Answers
Try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Posted on Jul 05, 2009
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
VIP 1225
Did you ever find a code to work???
Jan 19, 2010 | Yamaha HTR-6130 Receiver
Codes to program a yamaha remote rav283
This remote was sold with the HTR-6130 reeciver(among others.) The HTR-6130 manual contains instructions and programming codes. You can download the manual here: http://static.highspeedbackbone.net/pdf/Yamaha-HTR-6130BL-Manual.pdf
Dec 09, 2009 | Yamaha Televison & Video
I have the same problem
try to drop the 3 when programming that remote
Jun 12, 2009 | Yamaha HTR-6130 Receiver
Trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
May 24, 2009 | Yamaha HTR-6130 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
1,830 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
