Gw712
I have a code book for GWL08 & GWL10 and if the codes are the same for yours it looks like a problem with your cold water valve. The first thing the book says to do is check your wiring to make sure the valve is connected properly and if that does not take care of it to check the valves to see if the coil has an open circuit. If the valve is okay than they say the motor control module is bad and to replace it. Hope this helps you!
