Question about Whirlpool LSR5132PQ Top Load Washer
How can I find the size of my washing machine tub?
What is the tub size in cubic feet for maytag washing machine model no. a112
Why do you care??
Seriously...these machines are rated at 18 or 20 pounds but in reality it depends on the type of fabric and the size of the fabric. Think about it a moment.
Small items, say socks can be loaded well over the supposed limit but large heavy items may only wash well at half the rated load, the laundry has to have the ability to slide through the water in the tub. In spite of what most people believe, the laundry is not supposed to swish around going left-right, left-right but is drawn across the surface of the water, pulled down in the center of the wash basket and there the water currents are forced through the fabric, causing much less wear on the fabric and better cleaning results. Overloading the wash basket is The Major Cause of poor laundry results!
Jul 21, 2017 | Maytag Washing Machines
What's the tub size for a maytag A-211
Which tub? You have the inner tub where you put your things to be washed, then an outer to that contains the water for the washing cycle. Which tub did you need the specs for?
Oct 18, 2013 | Washing Machines
The tub inside washing machine has broken its supports
They are all the same size,
Just get one from a 5, 6 or 7kg machine.
Dec 26, 2012 | Fisher and Paykel Washing Machines
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Washing machine overflows no matter what load size
there is a sensor that tell the valve when to turn on and how much water should go thru the machine, it is a selinoid valve in the water line with a wire commming out of it,, you will either need to replace this your self or have a tech come out and tend to it
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
Mar 24, 2009 | Kenmore Washing Machines
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Washing machine problem...
A good marine type silicone sealant (like what you might use on boats) might buy you some time. However, with the vibration of the machine and the torque applied to the tub when the transmission and drive motor engage to spin will only make the crack worse over time. Sorry, but you might want to think about replacing the tub.
Aug 11, 2007 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Whirlpool LSR5132PQ Top Load Washer Logo
Marvin
Marvin
Michael Thomas
Michael Thomas
