Question about Champion 3500/4000 Watt Portable Generator
I hooked up pressure washer and used the remote and it started right away but then it shut off and does not want to start with remote or start button. I charged the battery the night before. The batte
I hooked up pressure washer and used the remote and it started right away but then it shut off and does not want to start with remote or start button. I charged the battery the night before. The battery was very low. The washer is not even a yr. seems like the battery should still be good
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 | Garden
I STARTED MY PRESSURE WASHER YESTERDAY AND STARTED RIGHT UP. AFTER ABOUT 2 MINUTES IN SHUT OFF AS IF THE SWITCH WAS TUNED OFF. IT WAS STILL ON. STOPED QUICKLY. WHAT'S UP. JEFF
Well there is a flaw with most power wasers and you cannot let them idle in bypass or that valve gets shot right away.but need more of a clarification like have you checked gas ,air oil?
Mar 09, 2011 | Garden
I have a Honda 4hp pressure washer it's been stored a few years but started right up . but does not develope high pressure
On the water pump there are two rows of large brass plugs. Behind/under each plug is a valve that, if they weren't properly prepared for storage, are either rusted shut or the spring is rusted away. Remove the plugs carefully so as not to round them off and check eash valve. If any are bad replace all of them.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
It shuts off during use then starts right back up.
Most of the time it is due to fuel lock - very hot engine. Easy to check, run engine with gas cap loose (not with full tank, fuel may spill out). Replace cap or open vent if necessary. Other problems include low or dirty oil causing oil senser to shut down engine, or hot engine due to obstruction of airway under cover and finally pressure set too high. I find that most pressure washers are set to max pressure. I like to set pressure to 70 % of capacity making components last longer. How long would a car/truck last if you drove it at max speed everywhere? Good luck with your repair.
Jul 07, 2010 | Coleman Pressure Washer PW0881800
Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
May 31, 2010 | Northstar Professional Series Pressure...
Pressure washer will not start
Do you get a spark? Take out the plug and leave the wire attached. Hold it close to the metal frame using INSULATED pliers. Have someone try to start it. Can you see a spark? Is the oil OK? Some engines have a low oil shut off.
Jul 19, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Please help me..
Maybe the 5hr. button is pressed? If so, the machine will wait 5 hours before it starts:)
Feb 09, 2008 | Asko W6021 Front Load Washer
Champion 3500/4000 Watt Portable Generator Logo
70 people viewed this question
Top Champion Televison & Video Experts
Lee Hodgson
Lee Hodgson
Harrie
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
