The model# is JCD2389GES. The door light in the ice dispenser area will not extinguish when the button is pressed. The light will adjust from normal to bright but will not turn off.
SOURCE: No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
SOURCE: Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
SOURCE: Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
