Question about Apple iPhone 3G
Debugged iphone 3g error on line 214 means and how to fix,debugged because no ringer headphone sound only
5 Related Answers
Anonymous
  • 30 Answers
SOURCE: iPhone 3G fix
Hi Molly,
I don't really understand why you want to disassemble your iPhone 3G, i guess it's your bussiness...
An iPhone 3G fix video i found -
Posted on Jul 17, 2008
Anonymous
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Posted on Aug 07, 2008
Anonymous
  • 221 Answers
SOURCE: iPhone 3g Connection Problems
AT&T doesn't have good 3G service. Often you may find that you do not have 3G reception, and the phone switches to EDGE. This is not a problem with the iPhone. I live in a metropolitan area, so I do not experience problems, since 3G coverage is good. However, when i travel around, often i go to EDGE as well. Like i said this is a problem with the network and not your phone.
Posted on Aug 13, 2008
Anonymous
  • 21 Answers
SOURCE: everything on my 3G iphone works except the phone will not work
try restoring the phone in itunes.
Posted on Apr 04, 2009
SOURCE: How to fix iphone 3g 2.2.1 Dialer, sms,
UPGRADE TO 3.1 FIRMWARE FROM ITUNES
Posted on Oct 01, 2009
Is it possible to make my iphone silent without use of button,,,...??
Plug in headphones
or
turn volume all the way down
or
Create/download a silnet ringtone and make it your ringer.
Hope this helps.
Matt
Feb 18, 2011 | Apple iPhone 3G
Headphones sign stays on and there is no sound
Same thing is happening to my iPhone,
The only way to fix it is to kick Steve Job's face in.
May 03, 2010 | Apple iPhone 3G
The ringer icon keeps appearing on the screen
Sorry but your Ringer switch needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself.
Apr 13, 2010 | Apple iPhone 3G
My iphone doesn't ring or vibrate, but does with earplugs on.
hey bro,
i fix more problem like your's. by change the flex up. with volume+vibrat button+headphone.
change this and all your problem will be good.
memeh Fixphone
Mar 29, 2010 | Apple iPhone 3G
My iphone will not ring and i checked the orange dot
Some users who have recently updated/restored to the new iPhone firmware 3.0 have reported to have got into a problem where their phone randomly doesn’t ring when there is a call nor does the keyboard or slide to unlock button sound anymore. I got into this problem as well after unlocking and jailbreaking my iPhone 3G with firmware 3.0, my iPhone suddenly stopped ringing on calls randomly, resulting in missing a lot of important calls.
So if your iPhone isn’t ringing sound on calls, or if you are unable to hear the keyboard or slide to unlock click sounds, then try the following fixes before you panic and call Apple support:
Fix #1: Push feature is currently not working properly on jailbroken iPhone’s. If you have installed an application which supports Push Notification System then try disabling the Push feature as it may solve the problem.
Fix #2: Try Resetting the iPhone: Settings > General > Reset > Reset All Settings. This will reset your phone’s setting to factory defaults. Your contacts, calendars photos and any other data will stay intact.
Fix #3: There is a slight possibility that your iPhone’s headphone jack may have got some dust or rust which is causing the phone to think that the headphones are still plugged in when they actually aren’t. Try blowing out air in the headphone jack or try plugging the headphones in and out repeatedly. This trick may solve the no sound problem.
Fix #4: Restore/Update you iPhone back and start afresh: If the above solutions doesn’t help in solving your problem then you will have to start from scratch by first restoring your iPhone to the the original firmware
3.0 from iTunes, jailbreak it using redsn0w and then finally unlock(3G users only) it using ultrasn0w. This has fixed my problem.
Fix #5: Install Insomnia from Cydia: Install Insomnia as your last resort. When you press the power button on the top, iPhone goes into sleep mode after 30 seconds, in the process turning off your WiFi, sound and other stuff. When Insomnia app (available for free from Cydia) is enabled, applications will keep running and sound & WiFi will stay connected when the screen is off. This should fix your problem if all of the above solutions have failed to fix it.
Dec 30, 2009 | Apple iPhone Smartphone
Service manual for 3g
Schematic? That's asking a lot, since I'm sure it's confidential, but I found this iPhone Repair Manual that will show you how to fix the screen, glass, headphone jack and menu button on an Apple iPhone 3G2_bing.gif.
Jan 15, 2009 | Apple iPhone 3G
Sound on video
the button on the side of your phone for changing volume is a multi choice button if you are in phone mode it turns ringer up/down in ipod mode it is music volume up/down etc.. other thing to check for is weather the mute button at the top on the side above the volume button has not been turned to mute
Oct 18, 2008 | Apple iPhone 3G
IPhone 3G repair
Hi:
Our company main products is IPOD and IPHONE repair parts, like lcd,front
panel,HDD,headphone jack,batteries etc.with 5 years experiences in China,With our
knowledge and experience in this line ,we guarantee satisfaction in reasonable prices,
high quality and prompt delivery.
hope we can enjoy many more years of doing business together.
Email:[email protected]
Link:www.ipartscity.com
Aug 05, 2008 | Apple iPhone 3G
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Apple iPhone 3G Logo
115 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
