Question about Kenmore Side by Side Refrigerator
Kenmore side by side click and whir noise but not getting cold
My refrigerator started to make this click whir sound - does it about 6 to 8 times and then stops. Refrigerator gets warm. If I unplug it for several hours, it gets cold again and stays that way for several days and then does the click whir sound again.
ndbooster
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
There is a coil called the condenser located on the bottom of the refrigerator, that may be plugged with dirt and or animal hair. Check and clean this coil and see if this solves your problem.
Posted on Feb 02, 2015
5 Related Answers
Anonymous
  • 67 Answers
SOURCE: Side by Side Kenmore Elite
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
Anonymous
  • 3 Answers
SOURCE: Kenmore refrigerator - both sides not working!
Your problem is most of the time dealing wih the defrost thermostat. To diagnose, look for the timer motor. Take a flathead screwdriver and turn it until it clicks. Then find the drain going to the drip pan underneath the refrigerator. If there is no water coming out after 20 minutes, the problem usually lies in the defrost thermostat (about 20 dollars) to replace yourself. Remove the inside panels leading to the evaperator and melt all the ice, cut out the the old defrost thermostat and splice in the new. To test it, put it in a glass of ice water. if after about 5 minutes there is continuity through the wires with an ohm meter, it is good. The problem is in the timer (maybe 50 dollars). As a general rule, the defrost thermostat will go bad first. One more thing that can cause your problem is a clogged drain from the evaperator section of the freezer to the drip pan. This cn cause ice to build up where you can't see it and air won't circulate well. My drain was clogged up with a piece of ice.I melted it with a hair dryer and now it works fine.
Posted on May 10, 2009
Anonymous
  • 403 Answers
SOURCE: Kenmore refrigerator stopped cooling 6 days ago
There are several things that could be causing this. Your compressor could be going bad. Your freon is low. Think of your refrigerator as a air conditioner. Pull it out and vacuum all the dust from your filters, make sure the water is draining properly and not clogged up. Is your unit still under warranty. How old is your unit. Try this. Unplug the unit for about 5-10 minutes, this will give it enough time for the compressor to cool down. Plug it back in and listen for the compressor to kick on. That's the big black round thing at the bottom in the back of your refrigerator. Listen to it and what the sound is, does it click when it turns on, does it shudder when it turns on. Let me know the sound. By unplugging the unit and doing this the compressor should kick on in 1-3 minutes after plugging it back in. If your unit is over 8 years old you might consider another one. Check out craigslist, as you can get some great deals. Let me know if I can help you further.
JimmyC
Posted on Sep 26, 2009
Testimonial: "Thanks so much for the fast response.I will try these solutions and get back with you."
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jan 26, 2010
kirkx
Kirk Augustin
  • 2019 Answers
SOURCE: I have a Kenmore 25351699100 side-by-side
Several possibilities.
One is that the relay is not making reliable contact. In which case it should just be replaced.
Another is the defrost heater is turned on by opening the door.
If the door switch was bad, and essentially stayed in the open position until the next time you used it, the defrost would heat up and melt the ice eventually.
While it would be hard to tell what the door actually did, because you can't see if the light goes out or not when the door closes, you could push the door button yourself, and see if the light always goes out as it should?
Posted on Aug 17, 2010
I have a kitchenaid Superb refrigerator KSCS25INSS01 and the temps are warmer than normal.
I have a similar problem, I have the same model number, mine is too cold in the the refrigerator but has the same " whirring/click noise" .I have removed the back cover and observed the condenser fan motor cycling on and off in 10 second or so intervals. the compressor is not trying to start so my guess is the control board is bad. I was hoping you have solved your problem before I buy a $250.00 part or a new "Frig" this one is 8 years old.
Lil help?
Nov 05, 2012 | KitchenAid KSRS25IL Side by Side...
Not staying cold
tell me do you hear a buzzing sound for about 5 sec ending with a click sound. every so often?? if so then you have a start device (relay) problem on the compressor you may think the unit is running b/c the lights are on and fan is on but if you hear that noise coming from the back of the unit while turned on then its the start relay or worse case the compressor is locked up..9-10 though usually its the start device
Mar 15, 2012 | Kenmore Side by Side Refrigerator
MY WHIRLPOOL SIDE BY SIDE IS MAKING WIERD NOISES - WHIRRING SOUND. COMPRESSOR?
A whirring sound? Can you tell whether it is coming for the inside of the freezer or underneath the unit? I would suspect one of the fans either blocked by something or starting to go out.
Jan 31, 2012 | Whirlpool ED5SHAXM Side by Side...
Not cooling the fan is working. there is whirring noise as if the compressor wants to start but it does not. this noise keeps on repeating
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Frigidaire Side by Side 26.0 Cubic Foot...
Kenmore Side by Side, hear a clicking sound every 10 mins. or so; freezer starts defrosting several times a week then freezes again. What is the problem?
heatman101
Mar 20, 2011 | Kenmore Side by Side Refrigerator
Side-by-side Kenmore GSI23 making buzzing/ humming noise and not staying cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 05, 2011 | Kenmore Refrigerators
I have a kenmore side by side fridge that is 6 years old and it is not cooling anymore. The fan is running and the compressor is warm. I hear a clicking noise when it turns on but get no cold air to come...
heatman101
Jan 03, 2011 | Refrigerators
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirpool
check the overload and relay on the compressor if the fan at the bottom is working then it sounds like the relay overload combo or the compressor is the problem
Apr 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
Dale Copeland
Dale Copeland
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
