Model number NED 7300WW1 serial #M20602334
SOURCE: Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
SOURCE: Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
SOURCE: While drying the dryer stops running every few minutes.
Have you checked the hose and ductwork to make sure it's all clear? It might not be able to ventilate.
SOURCE: Dryer will not start when button pressed. Several
is it a gas or electric model, if gas the ignitor,flame sensor,control board,if its electric,element,hi-limit,thermistor switch, control board, lack of correct input voltage,bad motor start capacitor on either model
