I'm not so sure repair is not cost-effective, especially as I doubt the quality of newer units. Mine broke after 20 years, amazing for a small appliance.
But I agree re safety. If the problem is more than a broken microswitch be wary.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
I would suspect the fuse or magnetron thermostat.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
The turntable system
consists of the motor, the coupler, the turntable support with rollers,
and the tray.
You can see and hear a video of how a turntable motor should
sound when you rotate it by hand.
If
yours won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven.
There
behind the
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can usually find
model number here.
We're
thoughtful rating of our answer.
There
should also be a "mini-manual" hidden inside the unit behind the
very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
