My ps3 skips entire sections while playing a dvd and also goes into fast forward
Get a dvd cleaner cd from walmart or target that is made for blu ray's and that will help you out a lot, if you have a console like mine where the top opens and you can access the dvd and see the eyes if the laser, take a q-tip with some isoproyl alcohol and clean both eyes off, but make sure the q-tip is not overly soaked since you don't want the extra liquid dripping into the console!
I have replaces 100s of weak lasers in ps3 s . I don't suspect the laser , I would check your hand controller. Start a movie and take it out of the room ( out of range ) if it plays the whole movie, problem solved just buy a new controller.
Is it possible your controller or remote may be malfunctioning?
If you use a controller, turn it off once you start the movie and see if it still skips.
If you use a remote, remove the batteries.
SOURCE: ps3 skip previews instructions
Get a VHS system. It's easy to fast forward and easy to copy movies and to record off of live tv.
SOURCE: just hooked up an fiber
gosnell6960
Most likely the default format of the video that you are playing is not supported buy your receiver. You may try to go into the audio setup and switch it to another format and/or try a disk that supports other audio formats to see if you still have the problem. They any are always coming out with newer versions of dolby and dts. So some times the new version is not fully compatible with the older receivers.
Let me know i you have any more problems or questions
Issken
http://www.fixya.com/users/issken
