Question about Benzhou Touring Scooter 250cc with trunk
I installed by mistake wrong polarity of battery
Replaced fuse but still no start.
Posted by Adelso Rodriguez on
Paul Williams
    New Friend:
  • 83 Answers
Does this scooter have electronics on it ? If it does then that is where you want to look. If it has electronic ignition you might have ruined the Module. Light bulbs will be okay. You will need a OHM meter and start checking out all the wiring and fuses (there should be more than one fuse) The charging system may have to be replaced too. Good luck to you
Posted on Oct 06, 2014
No lights working
Have the ECM/ CPU checked out as reverse polarity does wonders for burning out the systems . You may be lucky as a reset using a scanner may fix it
Mar 28, 2014 | Toyota Land Cruiser Cars & Trucks
Hooked battery terminals backwards
You have reversed the polarity for the CPU in the ECM This causes problems with the program at best and at worst will require a new ECM. Use a scanner to see if the program will reset and if not have the ECM checked for operation. You may have to have the alternator checked as well as reversing polarity blows rectifier diodes.
Mar 19, 2014 | 2003 Hyundai Tiburon
I have an Onan 3600 microquiet lp. I made the mistake of hooking up a jumper box to the battery with the cables crossed,now it blows the 5amp fuse that supplies power for starting. hope I didn't fry...
It certainly sounds like you have damaged the control board. If you cranked it with reverse polarity, there is a good chance that you have rotor winding damage also. If not you still may have to flash the rotor windings to ensure a correct polarized field. That involves hooking a battery for a couple of seconds to the rotor brushes (with correct polarity) with rotor brush wires disconnected. Only do this if there is no output voltage after you replace the control boards. Bad mistake :)
Aug 05, 2013 | Onan Microquiet Generator Lp Vapor 3600...
Replaced mega fuse now wont start
Putting reverse polarity to a battery will do more damage then blowing a fuse. Chances are you could have taken out the ECM and possibly the TCM
Mar 04, 2013 | 2006 Chevrolet Trailblazer
Polarity was reversed when jump starting vehicle installed new battery & no power to anything mechanic said fuse got blown.What fuse,where it is located & cost of it.
Hard to say without make, year, and model-but check all fuses in the power distribution box under the hood- ignition, alternator fuse, etc.-all of them, the small ones and the maxi-fuses. All fuses are pretty cheap. If you still have nothing, you may need a wiring diagram to check for fusible links that would be power distributors right off or near the battery. Fusible links work much like a fuse, and most have been replaced by maxi-fuses, but many vehicles have both. If there is a designated main fuse, it should be in the distribution block or box under the hood.
Feb 06, 2013 | Cars & Trucks
What is the fuse on the battery for
should be one on each batt. they are to prevent over amping the electronics and/or if batteries are installed wrong, polarity wrong, to keep them from damage or worse.
Sep 24, 2012 | Invacare Pronto M51 Power Wheelchair
Golf battery polarity
reversed polarity,check fuses. check the system for burnt wires also !
Always hook up your battery terminals correctly, as the alternator may be damaged if the battery is hooked up backward. jump start car, if it will. there should be at least 13.7 to 14.2 volts at battery posts while its running. if alternator is ok.
Nov 01, 2011 | Cars & Trucks
My son installed new batt backwards in 1996 buick skylark, now car will turn over ,wont start. did he fry the ecm and do you have any visuals?
CHECK IGNITION SWITCH 40 MP FUSE AND STARTER FUSE LINK.CHECK ALTERNATOR FUSE.MOST TIME IF BATTERY POLARITY HOKED UP WRONG YOU CAN FRY RADIO, ALTERNATOR, ECM, AND THE IGNITION SYSTEM.
Jun 28, 2011 | 2004 GMC Sierra 2500
Transmission problem will'nt go forward or reverse ford tarus 2005 54000 mile didn't give any warning just the gas padle started to stick after i hooked up the battery wrong
there is a fuse box under the hood with very large fuses in it, check and replace all the fuses that are burnt form the crossed cables.
Nov 08, 2009 | 2005 Ford Taurus
We brought a new battery to place the old one and
check your fuses. there should be 2 fuse boxes. one under the hood the other on the side of the dash on the driver side. possibly under the dash on driver side. it could also be relay that cannot be checked they can only be replaced and hope for the best
Oct 03, 2009 | 1997 Toyota Corolla
Benzhou Touring Scooter 250cc with trunk Logo
Top Benzhou Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Benzhou Audio Player and Recorder Expert? Answer questions, earn points and help others
