Model TZG990
SOURCE: Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
SOURCE: my beko fridge freezer keeps turning itself off
These appliance work with a thermostat that is when ever they reach a certain temperature they do cut off power automatically..If you find that ice is melting then you need to start worry.By the way the fat gas bottle is an air compressor which helps to circulate the gas around the system...It's like the heart of the fridge.
