After installing all new ink cartridges, running Nozzle Check and Print Head Cleaning, I still get very poor quality photos, mostly smeared with streaks of black ink. Could this be happening because my waste ink pad is saturated?
SOURCE: printer cartridge problem
I have a 440 and have had the same problem. Of course, I have been using cartridges from Printpal, Inkgrabber, etc. that are not official Epson. I have found that it takes several cleanings and after the cartridge has been in the position for the ink to go down it will start. My last order from Printpal said to set all the cartridges in the position they are in when installed in the printer for several days prior to installation. Of course, every cleaning of the print head uses up more of your ink. You don't have much choice though.
SOURCE: Printing partial color no black
Did you remove the plastic protector on the ink cartridge before you installed it?
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
SOURCE: epson photo 995 - black ink not printing
This is a common problem I have found with Epson printers. If you don’t use the printer on a regular basis the printer heads can clog. I have found no way to clean the heads once this occurs. I will now only purchase HP printers because the printer heads are part of the ink cartridges. With every cartridge change you get new heads, end of that problem!
SOURCE: My magenta ink will not print out. All other
Depending on the age of the printer and how often it is used it could be a dead piezo element in the magenta head or some dirt that is trapped in the feed mechanism to the head.That's why i never use refilled or poor quality substitute cartridges. Some Epson printers lasts for ages but unfortunately due to the head being permanent on all epson inkjets the only way out is for the replacement of the heads or a new printer. You could also try the magenta cartridge on another same model epson if you have access to one to see if the cartridge is perhaps a dud. Or alternatively purchase another cartdridge and check it out.
Using the Head Cleaning utility
Using the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
Note:
Refer to the appropriate section below to use the Head Cleaning utility.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that A4 or Letter size paper is loaded in the sheet feeder.
Make sure that this product is on and the ! Error light is off.
Access the printer software.Accessing the Printer Software for Windows
Click the Maintenance tab, then click the Head Cleaning button.
Follow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
Caution:Never turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
When Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
Note:
In most of htese cases it is good to have a reset to see if the driver software has errors. So remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
