Question about Frigidaire FEF368GM Free-Standing 30-Inch Electric Smoothtop Range, Silver Mist, 5.3 Cu. Ft. Self-Cleaning Oven with Advanced Bake Cooking System, 2,600W Bake / 3,000W Broil, UltraSoft Black Handles, 2 Oven Racks, Extra-Large, Clear Glass Visualite Window, Oven
The front left range element on our frigidaire electric range es300 does not appear to be heating at all. The unit's "Element On" light turns on, but the element itself does not come on. Eve
The front left range element on our frigidaire electric range es300 does not appear to be heating at all. The unit's "Element On" light turns on, but the element itself does not come on. Everything else seems to be working fine. Any ideas on how we can fix it? Thanks...
Posted by Scott Sprague on
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Good afternoon friend, thanks for your inquiry!
Based off the information you have provided me regarding your Frigidaire range element not working I am able to identify some possibilities with your range. It could be an issue with your burner switch or burner element. It would be best to have a professional come out and properly diagnosis your appliance to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Posted on Oct 07, 2014
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Dec 26, 2012 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire lower element not working
Does the element have continuity??Did you do an amp reading with the element connected?? Do you have voltage at the element terminals??If you have voltage at the element and you don't read amps when unit is on then it's the element.If it's the coil?The board should be replaced.Local appliance store may have it or can order it.
Nov 20, 2007 | Frigidaire fes365e Electric Kitchen Range
Doubel element
If only the outer ring of the element is getting hot then the element is bad. The elements should have a 5 yr warranty that covers the part only so check your owners manual.
Oct 06, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire FEF368GM Free-Standing 30-Inch Electric Smoothtop Range, Silver Mist, 5.3 Cu. Ft. Self-Cleaning Oven with Advanced Bake Cooking System, 2,600W Bake / 3,000W Broil, UltraSoft Black Handles, 2 Oven Racks, Extra-Large, Clear Glass Visualite Window, Oven Logo
166 people viewed this question
Top Frigidaire Home Experts
john h
Tom Chichester
Are you a Frigidaire Home Expert? Answer questions, earn points and help others
