Oven just doesn't seem to be working right in the bake mode. Turn on - preheat button lights up and goes out, then start baking and the preheat light will come on again and the food never gets cooked. Read somewhere recently that the clock fuse is related. Not a digital clock, but one with hands. Clock has also stopped. Any info appreciated. Thanks
SOURCE: Can't turn off my Kenmore 47833
check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
SOURCE: Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
SOURCE: bake, broil & clean buttons do not function,
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
SOURCE: when I turn my oven on to bake it goes on and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Get it repaired from authorised personal. Seems sensor elements has gone down or programming chip is malfuctioning.
