Just bought colemon powermate 1850 maximum watts 1500 running watts need to no if i have to mix the gas or not and if you no what kined of oil to put in motor
Does it have a dipstick that indicates the amount of oil?
If it has, it is a 4 stroke and does not require an oil/fuel mix.
If it does not have a dipstick, it is a 2 stroke and will require a mix of oil and fuel.
Without knowing anything about your genset, I would think that it is a 4 stroke.
A 2 stroke motor would deliver the power too high in the rev range.
SOURCE: oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
SOURCE: I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
SOURCE: What oil do I use in a Coleman Powermate 1850
Even though Powermate generators are discontinued they still have a website with owners manuals at www.powermate.com.
SOURCE: coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
