Question about Kirby Generation 3 Bagged Upright Vacuum
Instructions all i am trying to do is get the steps in how to put kirby generation 3 back together
Posted by renee4u on
  • 1 more comment
  • renee4u Nov 10, 2007
    i donot want to pay for instructions where is the site to download the instructions
  • Fred Swick
    Fred Swick Mar 02, 2008
    How can you tell if the switch is defective other than the vac not running?
  • zman2678 Mar 19, 2008
    ok my gen 3 kirby will not ****? i tried to take it apart but couldnt figure it out i put all screws back in ect ect plugged it in then the vacuum took of fast as hell this wasnt doing that before i cant even control it lol. is there a downloadable instruction manual that u know of?
Uplate
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Http://www.greatvacs.com/kirby%20instructions.shtml
this site may be helpful if youre trying to put the kirby together into the upright vacuum configuration.
Posted on Jan 14, 2008
Kirby G4 spaking after repairs???
Often the armature needs to be resurfaced when the brushes are replaced...Why were you replacing the brushes? Did the fan break?
It's really not that expensive to take it to a Kirby dealership for repair. Will run forever....Also it came with a lifetime rebulid warranty so even if it's trashed you can ship it back to the factory for rebuild for like 200 bucks :)
May 26, 2013 | Kirby Generation 3 Bagged Upright Vacuum
How to put together Kirby ultimate G vacuum cleaner the rubber part in the inside.
We actually recorded a very informative video repair with this exact problem. This will walk you through step by step on how to replace the belt (the rubber part) on all Kirby Generation uprights (including your Ultimate G). Also it will show you how to do basic maintenance on the brush while you have it out.
If you haven't already purchased a new belt, here's a direct link to the belt your vacuum uses on our website:
Kirby Generation Vacuum Cleaner Belt. Kirby Part # 301291A
If this video is helpful to you, please help other Fixya users that have the same problem find this video by rating the repair helpful. You can do this by clicking on the 4 Thumbs Up Icons in the top right hand corner. If you have any questions, please don't hesitate to ask.
Here's the video:
Chris J.
GoVacuum
Apr 10, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do I assemble kirby g3 carpet cleaner?
Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby G3, as well as Kirby Diamond Edition, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Instructional Video On How To Attach The Kirby Generation 3 Series Carpet Shampoo Attachment:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this video was helpful to you. Please feel free to request a clarification if you have any further questions about the installation, I'm always more then happy to answer any question, seriously.
If you did find this video helpful, please kindly rate my soltuion as Helpful by clicking the Thumbs Up Icon at the the bottom right hand corner of this page.
Thanks for watching!
Chris
Mar 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
How do I use shampooer?
Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The Vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby G3, as well as Kirby Diamond Edition, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Chris
Mar 10, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I need instructions on how to attach the Carpet Cleaner attachments to a Kirby Ultimate ( about 7 or 8 years old )
Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby Ultimate G, just as it is with Kirby Generation 3, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Instructional Video On How To Attach The Kirby Generation Series Carpet Shampoo Attachment:
Chris
Feb 27, 2010 | Kirby G5 Bagged Upright Vacuum
We have a kirby generation 3 and it slows down and speeds up almost sounds like it is going do quit could this be a brush problem in the motor sometimes it will quit.
You may need to service you Kirby. Go this page HERE, fill out Service Request Form and ship to us together with you Kirby. We will inspect it and will call you with an estimate.
Good Luck,
Rocky
Dec 09, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby carpet cleaning problems
http://www.greatvacs.com/kirby%20instructions.shtml
Note: This is just a website i found with the instructions. Don't hold FixYa, or me liable. But it did look pretty spot on when I did a quick browse through.
Hope this helps.
Apr 30, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby generation 3 fan
You have to take off the top cover, then the handle pivot. Look down at the back of the armature you will see that it has a flat spot, you use a small vise grips or pliers to hold it, turn the belt pulley to the right if I remember right and turn the pulley off. If it won't come free, use a couple of flat blade screwdrivers and pry up to pop the fan off. Then put it all back together.
Feb 11, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
135 people viewed this question
Top Kirby Vacuums Experts
Marvin
Marvin
Lollo Pop
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
