Ovens Logo
Question about Ovens
Find Baumatic BAF90EG COOKER
INSTRUCTION BOOKLET
jfhinton45
  • 3,506 Answers
Do a web search for the unit manufacturer and usually instruction booklets are available there.
Posted on Oct 05, 2014
2answers
My beaumatic oven fan light and heating up is not working but clock and timer is fine,can any one help
If you have a problem with your Baumatic B180 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
How to fix the main oven in our Baumatic range cooker?
Although elements look in one piece they can go 2 ways, short circuit (visible normally by a bulge or tear) or the resistance gets way too high, They should normally be around 30 ohms resistance reading. Use a multimeter and check the ohm's reading of the element
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Instruction manual for delonghi excellence elba px906 model cooker
contact user mazandhan on ebay uk for new booklet.
8 settings., last is top/bottom/fan
Nov 15, 2010 • Ovens
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
2helpful
2answers
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 • Ovens
24helpful
2answers
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Fitting this cooker into an under bench unit
Yes
Should be no problem as long as you have some kind of vetilation.
Top Ovens Experts
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
