Question about GPS
Navman 450MLT worked fine until I went to do the first update of the maps - unit stalled during the process, and now won't work (no maps). Smart recovery does nothing. How do I un-brick my Navman?
Daniel Harty
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
If you have any chance of receiving a repair or replacement unit from Navman, do that. I do not know their return/repair policy but trying to fix it yourself may void any chance you have of getting real customer support, unfortunately.
Otherwise, take a look at this post:
In particular: http://forums.whirlpool.net.au/forum-replies.cfm?t=2014297&p=2&#r23
He says there is a paperclip hole. This should do a factory reset and may fix your device. Otherwise he claims that reformatting the drive then "safely disconnecting hardware' may fix the device.
Posted on Oct 05, 2014
5 Related Answers
Anonymous
SOURCE: maps update
Navman is awful on support for map updates, which they claim are the latest. I've had mine less than a year and have decided to sell it and replace it with a Garmin. You can get maps that are 1-3 years old, even though Navman says 10 months old, for $149 USD. Horrible Company, it should be struck by lightning and let it burn to the ground!
Posted on Jan 23, 2008
Tiny Tim
SOURCE: Map update
I got news for you poor Delphi Nav200 or 300 suckers , I mean customers. There is in fact a map update right now, but guess what. The assholes want $99.00 for it. Go buy a Tom Tom. All updates are free. All the time thru their web site.
If you want to BUY the update from the Delphi Crooks it's up t6o you. I will be a good duby and give you the website. Ready, here it is are you sure???? OK !!!!! It's your money.
it is, Oh I just can't do it to ya. Sorry
Posted on May 05, 2008
Anonymous
SOURCE: Suddenly all detailed maps are locked, I can't unlock them
I had the same problem so I went to garmin.com/kenwood and downloaded the latest update to my pc unzipped the file and burned it to a cd put the cd in my dnx5120 and updated my system and my maps came back ... read the install instruction on their web site and this should solve the problem at least it did for me ....good luck hope this was helpful to all ...
Posted on Mar 26, 2009
Anonymous
SOURCE: Navman s30 3d 2009 map update is useless
You should be able to install your old map from the DVD/CD that originally came with your Navman - you don't need a Product Key for this, even if it prompts you for one.
It appears that the commercially available 2009 map for the S-Series does *not* cover the S30 3D, just the non-3D versions, although that's not at all obvious from what's on Navman's web-site, so you have my sympathies if you bought it expecting it to work...
Posted on Sep 29, 2009
crep1206
crep1206
SOURCE: Roadmate 5045 slow after update
Magellan support was actually pretty good helping me with the exact same issue. The problem (at least in my case) was that the map files were fragmented. I tried using the Windows defragmenter, but that made fragmentation even worse! The Magellan support engineer recommended I download UltraDefrag instead:
http://ultradefrag.sourceforge.net/en/index.html
Here's what I had to do to completely resolve my issue:
1. Download and install UltraDefrag
2. Connect my GPS to my PC
3. Move the MAP directory from my GPS drive (J:) to my hard disk
4. In UltraDefrag, make sure Action > Skip removable media is not selected
5. Run the optimizer (Ctrl-F7 or Action > Full optimization) after selecting the GPS drive (J: on my computer)
6. Copy the MAP files back to the J: drive AFTER optimization has completed
I double-checked the fragmentation after the files were copied and got 0%. After disconnecting the GPS from the PC, the unit rebooted and doing an address search no longer takes 15 seconds. POI searchs are also much faster than before.
Posted on Mar 17, 2013
I have a Finedrive 400 GPS unit. Is their a place that I can download the driver for Windows XP, and then update the map? The unit works OK now. We have had it for about 10 years. Thanks, Mike
FineDrive 400's were manufactured by Navman, but are not supported anymore in any fashion, no updated maps, no op system upgrades, no Windows drivers or anything. If and when it malfunctions, you may be forced to get another unit.
Mar 28, 2011 | Fine Digital FineDrive 400 GPS Receiver
I HAVE DELETED THE MAPS FROM MY S30 NAVMAN .WHEN START UP THE UNIT IT SAYS THERE ARE NO MAPS. I DO NOT HAVE THE DISK FOR THE NAVMAN EITHER. HOW DO I GET THE MAPS BACK ON
Download the Navman S30 update click HERE! and save it on your desktop .
Also download the Navman S30 manual click HERE! -->page 96 for instructions .
Jan 10, 2011 | Navman S30 Car GPS Receiver
I want to update my model how do I do it and how much will it cost
Depends on what you mean by update. If you want to exchange your unit for a newer model, that is between you and the dearler/seller.
If you mean that you want to update the software in your unit to more updated maps, then do this:
Go to this site, and select your model, then choose update maps. You will likely have to download the maps file to your computer, then transfer then to your device. Instructions should be on the Navman website.
http://www.navman.com
good luck and don't forget to vote!!!
Oct 11, 2010 | Navman N40i Handheld GPS Receiver
How do you get up to date maps for navman my55T
Start at the navman website.
I should pre-warn you that they are not very friendly. About 4 years ago I bought my mom a Navman ICN 620, after 6 months I tried to get updates and called and emailed them for about four months finally when they responded they just said they were not updating US maps for any of their previous products. Looks like they are more an international company that sells in limited quantity in the US through Radio Shack stores. I have gone back to their website about 5 times since then to see if any updates were ever added and they never did.
If its an older unit I would replace it Tomtom makes a nice unit and Magellan even has a few units with free traffic updates (depending on area)
I finally just replaced the unit for her this christmas bought her a Magellan roadmate 1470 for $150.
Just FYI most GPS manufacturers want you to pay YEARLY for their map updates and if you skip an update you may have to also pay to do a firmware update. I have a Tomtom go 720 which is 2 years old they wanted $49 for a firmware update and $99 for the map update.
Jan 12, 2010 | GPS
Sep 17, 2009 | Navman NavPix N40i GPS Receiver
Upgrading map on navman f15
There are both software updates and new maps for the F15 available at Navman's website, I've updated mine no problem.
Aug 25, 2008 | Navman Personal Interactive Navigation GPS...
Operating temperature Navman icn
The unit has two temperature sensors that prevent it from overheating - there is one on the circuit board, and one on the back of the screen. Sounds like one has gone faulty!
May 06, 2008 | Navman ICN 635 GPS Receiver
Navman S50 wont load maps
Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
Feb 08, 2008 | GPS
Navman S80 will not let me go passed the safety agreement
When I turn my unit on all I can see is the accept/decline screen. The unit will not load the maps. How can I fix this?
Step 1
Connect your Navman Device to your computer via a USB cable.
Turn on your device and you will see a connection screen appear.
Step 2
Wait a few Seconds until a window appears on your desktop and then select “open folder to view” by double clicking on it
Step 3
Once you have opened this folder you will need to double click on “My Documents”
Step 4
Once my documents is opened locate and files that starts with “LOG00” and also “My Mileage” and delete them
Step 5
Once the above steps are done you may disconnected your unit from the computer.
Turn your unit on and enter your main menu page 2/2 and select “Preferences” then select “Route Options”
Once this is selected go to page 4/4 and un-tick “Enable GPS data logging” and “Enable trip recording”
Your unit is ready to use and will run a lot smoother due to increasing unwanted data and freeing space to increase optimum performance. We suggest that you follow these steps once a month to ensure optimal performance.
These steps will work on the S50, S80 or S90i. If you are experiencing this issue on an S30 or any other device, please contact Navman Technical Support on 1300 628 626.
I used this personally on my S80 after it died during my work as a Security Patrol officer and I was not happy, its all fixed now and I have my Nokia N95 loaded with the same places just in case.
Feb 04, 2008 | GPS
GPS reception
Navman in no longer offering map support for it's iCN 510. This means if there is a new road or community, this unit will not recognize it.
I am really mad about this. I spent $400 2 years ago for something that will not have anymore map updates. Here is there reply when I wrote to them about it. Class action suit anyone?
Dear Henry,
Thank you for contacting Navman Technical Support.
We do apologize for the inconvenience. Navman has decided not to release further map updates for these device due to changes in technology over the last year. We have changed the chipset1.gif and software1.gif platform and are unable to update this device. The Navman 500 series was released with an updated map version last 2005.
If you need further assistance, please do not hesitate to contact us, we'll be more than happy to help.
Kind regards,
Ofelia
Technical Support Team
Navman USA
C/O Mio Technology USA Ltd.
47988 Fremont Blvd.
Fremont, CA 94538
Office: +1 (866) 962-8626
www.navman.com
Jul 16, 2007 | Navman ICN510 GPS Receiver
GPS Logo
75 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
