Question about Emerson Smartset Clock Radio
I need a owners manual for my alarm clock I need to change the batterys and donot know where they are located
2 Suggested Answers
Anonymous
SOURCE:
Ranglo
Ranglo
  • 1194 Answers
SOURCE: Manual for Emerson smartset alarm clock
As you haven't mentioned the model no. so I am giving you a link from where you can download the manual for your appropriate model.
Good luck....and have a nice day. Rating the solution is highly appreciated.
Posted on Mar 19, 2010
The time is wrong on clock. how do I set the right time?
on battery operated clocks, take down clock and turn small wheel on battery unit. on cars and other clocks, see the owner's manual. on digital alarm clocks, you need to
hold down 2 buttons.
Mar 03, 2018 | The Audio Players & Recorders
How to raise and lower the volume on the alarm on a model 4248 alarm clock
BRIAN, DID YOU GET A MANUEL WITH YOUR CLOCK-RADIO LOOK IN IT OR CALL MANUFACTURE CUSTOMER SUPPORT
Jan 21, 2016 | Audio Players & Recorders
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
Alarm function quit working for sat. and sun.
You can try to take the battery out of the clock/radio and disconnect the plug. This will allow the microprocessor to lose power and reset itself to the factory set-up. It will take about a hour to make sure its discharged. Then put the battery back in the clock/radio and see if the functions return to normal. You can go to this web link.(http://www.emersonradio.com/owners) copy and paste this web link into the address bar of the browser and it will take you to the Emerson website with all the owners manuals listed by make and model. You can find you make and model clock/radio and follow the instructions for resetting the functions. I hope this information helps you with your problem.
May 03, 2009 | Emerson Smartset Clock Radio
I on the projector type clock only one alarm is workingneed to know how to set both alarms
[http://www.emersonradio.com/owners] Copy this web link and paste it into the address bar of your browser. It will take you to the Emerson customer support web page with all the Clock/Radios owners manuals on it. Just find you make and model number and open the pdf file of the owners manual.In the manual will be all the instructions to set the second alarm on your Clock/Radio. You can also use the print function on your computer to make a pdf copy for yourself. I hope this information helps you solve your problem with setting the second alarm.
Feb 26, 2009 | Emerson Smartset Clock Radio
Clock Setting Mercedes benz ML320
pull on the noob right next to the time one way changes hours other way changes min. !!!!!!!!!!!!!!pull hard on noob that you can turn it!!!!!!!!!!!!!!!!!
Jan 09, 2009 | 2007 Mercedes-Benz ML320 CDI
Setting the days of the week
Sorry it took so long to give you a solution to your problem.. You can find this information on the following web page link. It will take you to the Emerson customer service web page main index for owners manuals for all the Clock/Radio products.On this page you can match the make and model of the owners manual to your make and model of Clock/Radio. You can then find the correct instructions to fix the problem with the Clock/Radio's alarms. You will need a pdf reader to read the owners manual. [http://www.emersonradio.com/owners] Copy this web page link and paste it into the address bar of your web browser and it will take you to the page of the index for the owner's manuals. If you are still having problems with the setting of the alarms, you can call the Emerson customer support at this telephone number. 1-800-909-1240. call them between the hours of 8am and 4:30pm central time USA. Give them the make and model of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem with the Clock/Radio's alarms. Thank you for using FixYa and have a nice day!
May 25, 2008 | Emerson Smartset Clock Radio
Model#cks2288b clock radio
Sorry it took so long to get you a solution to your problem. You can find this information on the following web page link. It will take you to the Emerson customer service web page main index for owners manuals for all the Clock/Radio products.On this page you can match the make and model of the owners manual to your make and model of Clock/Radio. You can then find the correct instructions to fix the problem with the Clock/Radio's alarms. You will need a pdf reader to read the owners manual. [http://www.emersonradio.com/owners] Copy this web page link and paste it into the address bar of your web browser and it will take you to the page of the index for the owner's manuals. If you are still having problems with the setting of the alarms, you can call the Emerson customer support at this telephone number. 1-800-909-1240. call them between the hours of 8am and 4:30pm central time USA. Give them the make and model of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem with the Clock/Radio's alarms. Thank you for using FixYa and have a nice day!
May 05, 2008 | Emerson Smartset Clock Radio
Can't change alarm
Sorry it took so long to give you a solution to your problem. You can find this information on the following web page link. It will take you to the Emerson customer service web page main index for owners manuals for all the Clock/Radio products.On this page you can match the make and model of the owners manual to your make and model of Clock/Radio. You can then find the correct instructions to fix the problem with the Clock/Radio's alarms. You will need a pdf reader to read the owners manual. [http://www.emersonradio.com/owners] Copy this web page link and paste it into the address bar of your web browser and it will take you to the page of the index for the owner's manuals. If you are still having problems with the setting of the alarms, you can call the Emerson customer support at this telephone number. 1-800-909-1240. call them between the hours of 8am and 4:30pm central time USA. Give them the make and model of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem with the Clock/Radio's alarms. Thank you for using FixYa and have a nice day!
Mar 16, 2008 | Emerson Smartset Clock Radio
Emerson Smartset Clock Radio Logo
166 people viewed this question
Top Emerson Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
