Avantixx 7 VarioPerfect WAQ284G1/01
The actual error message 61 is a door lock error
https://www.fehler-code.de/waschmaschine/fehlercode-e61-6/
Translated:
Unplausible door signal. Possible causes:
- Door-lock is active, but door is open.
- Emergency (manual-) opening mechanism was used.
Solution:
Check door lock, mechanical aspects, loom
I ordered a new door lock, which wasn't delivered in a timely matter. Then it appeared to be the wrong one. Then I ordered the correct one .. looked different as my old type, but the reseller confirmed it was the right one. Mounted it, did'nt work. Checked the PCB if all PCB-relays controlling the safety chain were actually working .. all fine. Felt really sad. Untill I read the above: push start button for 5 seconds. Solved.
I wish I visited Fixje right away.
Great answers thanks saved my 3000
Did you read the manual ?
SOURCE: washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
SOURCE: Hi. My Bosch Avantixx 6
Hold the Start/Reload button for 6/7 seconds till the symbol disappears.
SOURCE: Bosch excell 7 varioperfect washing machine will not programme, the key flashes on the display
Dont worry your machine is ok
the flashing key means your child lock is on, and has to be disengaged
What you need to do is press and hold the on/off button for approx 5 seconds This should turn the lock off.
I hope this was useful.
SOURCE: Hi, I have a Bosch
My Bosch Avantixx 6 VarioPerfect smells and therefore the washing smells.Any solutions?
Same for my Siemens WNAS324471/57 Logixx7 VarioPerfect
