They are not comunicating
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Philips PM3S - 3-Device Universal Remote Control
Here is your product manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000053128.pdf
It includes the codes for your remote. :}
If you dont see your product on the code list try a code search. If this fails your remote might not support your device.
SOURCE: remote codes for "ph301s" universal philips remote
www.remotecodelist.com .............................T.
SOURCE: philips remote control pm435s user manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm435-manual.zip&area=other
Here is the Code and Manual for that remote. Thanks //D
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: Need codes for Philips Universal Remote model
I found the correct code by alot of trial and error and going through every number from 000 to 999 to find the correct code.
