Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
My code does not work and I don't my key the code keeps changing by its self
Cant open with code because it keeps changing by its self and I don't have the key
I have a 2003 Cadillac Escalade, and I recently had a print out done on my vehicle. I'm not understanding these codes: aa1 poor connection at the TAC module, aa2 failed TAC module, aa3 check TPP or TP
I always ask---If you went to the trouble to have
it scanned & get a nice print out & I would assume
asked all these questions at the shop,then why
did you not leave it,to be further component tested
& issue resolved?
TAC -throttle actuator control
The drive by wire motor that opens the throttle
body plate
TPS Sensor--throttle position sensor on the same
Try spraying some CRC Throttle Body Cleaner in
there around the throttle plate
After that you need to have to tps sensor tested
I wouldn't be in a hurry to change a throttle body,
they cost hundreds & the codes don't tell you it's bad
The only time you replace a throttle body is if you can not
get the motor by it's self
Oct 02, 2012 | Cars & Trucks
Certain keys on my keyboard don't work
if you or some one you know has an account with ebay go to ebay and look for the keyboard they don't cost to much.then go to youtube and type how to change the keyboard for your loptop model and watch videos and you will be able to change it is simple beleave me.i have doned my self.and im not an expert person.
Aug 11, 2012 | Toshiba Satellite Computers & Internet
One for all remote codes don't work URC-3920
Hi keep teaching should come up with more if still dosent work try one for all web site or phone them very helpful
Aug 04, 2012 | Televison & Video
Nokia 6600, Imei no. 359365004705343. Two viruses are in my mobile.so i will reset it. but i don't have lock code. Send me the solution.
best result : just download unlockme.sis application & install it on your nokia 6600 and open it after 10 to 15 minute lock code appear on display .
to remove virus you have to formatt your phone , frist switch of your phone & start the device by pressing combination key green key ,' * ' , ' 3 ' , ' power on/off switch ' you will show formatting on display , make sure that procees remove contacts messages etc. so please back up your data before formatting
Jul 19, 2012 | Nokia 6600
I have a Pfaff 418 and suddenly the bottom thread keeps snapping after about 5cm. I've altered the tesion & the timing and it's still happening. Any ideas??
try changing the needle
try rethreading the machine
clean under the needle plate & in the bobbin area for lint or threads
if these suggestions don't help, then the machine needs to be checked
to see what wrong with it
May 29, 2012 | PfaFF Sewing Machines
Factory code for keyless entry on a 2005 ford freestyle se
You wouldn't really expect the whole world to know
your code would you? Your on the internet,people
know you & want to steal your vehicle
You go to a dealer with your tittle,registration,drivers
licence
They don't just give that to anybody
They will give you the factory code
Why don't you have the card it came on with
the owners manual?
If you got no manual, have the dealer write down
how used the key less entry & how to change the code
Aug 06, 2011 | 2005 Ford Freestyle
Code po443
EVAP Purge Control Valve Circuit
I don't have a break down on all the evap codes
There are others that say the same thing & I do not
want to tell you to change any part,no one should
You always use the codes to guide you to a system
area & then do some testing
You will need a repair shop
Don't throw parts at it
You can learn a lot on YOU TUBE about what an evap
system is & how they work
Also several parts manufactures web sites have educational
video
You can watch that stuff all day long for years & never see it all
No reason not to educate your self when you have an internet connection
Aug 04, 2011 | Dodge Grand Caravan Cars & Trucks
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Jul 02, 2011 | 1998 Lincoln Continental
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
315 people viewed this question
Top Safe International Locks & Locksmithing Experts
Marvin
Marvin
john h
Sheldon Dedek
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
