Question about Brother Office Equipment & Supplies
Is there a way to reset admin password on brother Mfc-6910dw
4 Related Answers
Anonymous
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
jtuminaro
John Tuminaro
  • 56 Answers
SOURCE: Need to reset 'Drum near end' warning on Brother MFC-8460N.
Open the front door
Press clear
then press 1
Posted on Jan 15, 2009
Anonymous
SOURCE: admin password for Canon ir2270 MFC
JUST HAD THE SAME PROBLEM. THE DEFAULT ADMINISTRATOR PASSWORD IS "BLANK" LEAVE THE PASSWORD FIELD EMPTY AND PRESS ENTER
Posted on Feb 17, 2010
Anonymous
SOURCE: Factory reset Brother MFC-7320
1. Open cartridge cover
2. Press the button Clear / Back
3. Press start button
4. Print number 11
5. Close cartridge cover
Now, your printer is returned to the factory settings.
Posted on Jul 27, 2010
2answers
I replaced the fuser. How do I reset the fuser?
Reset fuser instructions video for similar printers:
2answers
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
How to reset ink absorber full Brother MFC - J6910DW . Please explain
This link has all the guides and manuals for your printer...free. The basic and advanced guides explain the error and also have a section on how to reset the machine.
Manuals MFC J6910DW United States Brother
3helpful
2answers
Reset the drum counter on Brother MFC-8950DW
To reset the drum counter on a BROTHER MFC-8950DW open the front cover, press the start '*' button on the keypad, the screen will show the reset menu, click drum, click yes, and you will get a message on screen accepted. The procedure listed in the brother manual for this machine is wrong and does not work.
Brother mfc-7840W not picking up wireless IP address
It is common, mainly because the MFC connection is lost to your PC. Are you able to print or scan from another wireless PC that you have? If yes, contact your network admin or router oem. If no, reset network card. Run the Setup Wireless Wizard. Make sure you have router info such as SSID, Network Security Key, Authentication Method (Open, Shared, WPA/WPA2-PSK), Encryption (None, WEP, AES, TKIP). Enter those info, it must be CASE SENSITIVE. Just in case you dont know your router info, contact your router oem.
For Advanced Users.1. Click your Wireless Icon at Task Tray2. Right-Click your Wireless Network Name3. Select Properties4. Go to Wireless Security Settings5. Take note of the settings that you have there and enter it again on your MFC
Goodluck! If you still need more assistance. Call us 1-877-Brother. :)
2helpful
2answers
How to unlock the router password
default user name password for router is admin admin
if your brother has changed it then u have reset it ocad33c4.jpgn factory setting
3helpful
2helpful
Oh brother
I don't think there is a reset procedure for resetting MFC 3240c cartridges.
Professional refill facilities use a code reset device on cartridges.
Users that want to refill their own cartridges often use a piece of cellotape or plastic bag to cover cartridge sensor. This can damage printers head if ink goes too low and printer keeps printing.
My suggestion: stay away from troubles and buy original cartridges.
Here is a link on howto:
Reset ink sensor for Brother MFC 3100C - fixyourownprinter.com
Norman  J Weimar Jr
Norman J Weimar Jr
Gary
Gary
