Question about Dell Inspiron 8600 Notebook
Dell error code ofoo 0131d
This error comes when running diagnostics but error is intermittent in that sometimes notebook runs good,sometimes not,it seems slow and I did replace DVD r/w drive now thinking maybe it might be hard drive
Smith William
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Dell Expert
  • 241 Answers
List of common Dell printer error codes:
Have a look at some of the Dell printer common error codes with their suitable solutions:
Replace Toner:
One of the most common Dell Printer errors is "Replace Toner" error. This error often appears due ink color or not using Dell toner cartridge. On any such occasions, you need to replace the Toner Cartridges to dismiss this error message.
Solution: Identify the faulty Toner cartridge and replace it with new or working one.
Paper Jam Tray 1 and Tray 2 error codes:
Paper Jam Error in printers in general appears when a debris piece of paper struck inside it. When a physical jam occurs blocking the printing path, this error message occurs.
Solution: To fix this error, you need to clean the printing path by physically opening the physically opening the printer's door. Remove any piece of papers that is struck inside the printer.
If you want to know more then kindly Visit this site: Dell Error Codes
Toll-Free No: +1-888-633-7151
Posted on Aug 02, 2019
KiranK
    Sergeant:
  • Dell Expert
  • 352 Answers
It is unfortunate that the computer displays an error code as "ofoo 0131d". Request you to use the below link and install My Dell:
http://dell.to/1cn35y5
Then run a diagnostics using My Dell and let me know the test results.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Posted on Oct 07, 2014
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: I am trying to reinstall Windows Vista on Dell
try not to delete partition 0 recovery disc, just delete partition 0 operating system
Posted on Apr 29, 2009
Anonymous
  • 89 Answers
SOURCE: My dell 610 laptop has started running slow
No
you have a few options.
1. download and install CCleaner and Defraggler run these cleaning tools to get rid of unwanted data.
2. upgrading your RAM will help.
3. Reinstall windows remembering to backup all your data first.
Posted on Nov 26, 2009
IQUIT
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
Hostinz
  • 188 Answers
SOURCE: Dell inspiron 1545 notebook error
The error codes and the fix for all the error codes are available in the following link....
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
Posted on Dec 14, 2010
Peter Passaretti
  • 102 Answers
SOURCE: My Dell Inspiron 1545 will
Ouch, I hate it when that happens. There are some diagnostics available on the web (or from a buddy) that can be made bootable. Two come to mind:
Ultimate Boot CD for Windows www.ubcd4win.com
Hirens BootCD www.hiren.info
You will need to download the data and then follow the instructions to create a bootable CD. If you're a geek this could be a fun project... if you're not a geek and don't want to spend some time... then don't bother.-, it could be troublesome.
It sounds as if you have already resigned to a new HD or rebuilding your system from scratch... you could borrow a Windows CD from a friend and attempt a Repair. Just make sure to get the same version of Windows.
You can also bring the machine to Staples, Office Depot or some other store that does repair work. If you purchase a new HD and have them install it, they should be able to recover your operating system.
Posted on Aug 18, 2011
Intermittent fault on slowing down sometimes cuts out on very slow cornering. its a automatic making it a pain . removed throttle body and cleaned still problem
Is the fuel supply okay? Has it been cleaned ? Is idle speed set correctly as a matter of interest. Sometimes if the fuel supply is just a little diminished and the enginde is allowed to run more slowly than it should under load , can result in bad behaviour. Agood tune and fuel system clean may do the job. Probably best to get it on an electronic diagnostic system
Jun 05, 2015 | 1999 Toyota RAV4
Error code 0146 what does it mean?
This is indicative of a hard drive problem:
A user may report they receive an 0141, 0142, 0146 or a 0151 HDD (Hard Disk Drive) error on their Dell Desktop or Laptop system.
The Hard Drive may still continue to work but there may be other issues that could manifest themselves as an intermittent failure to boot to Windows, a slow system or noise from the Hard Drive.
If possible, before carrying out any troubleshooting steps on the Hard Drive, please make sure you have a verified working and up to date backup of your data
You could run the built-in diagnostic tool to determine specific HD problems, using this procedure:
To run the Enhanced Pre-boot System Assessment (ePSA) diagnostics, perform the steps below:
  1. Restart the computer.
  2. As the computer boots, press <F12> when the Dell Splash Screen appears.
  3. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics and press <enter>
  4. A graphical menu listing all discovered devices in the system is now displayed.
  5. Select Hard Drive and click Run Tests to start diagnostics.
Oct 02, 2013 | Dell Vostro 1015 Laptop
Techumseh 195cc lawnboy runs fast then slow then stops
Replace spark plug and air filter.
May 27, 2013 | Garden
Toshiba Laptop M305-4910 starts up and runs very sluggish
I/O error means input or output error. the Hard drive can't read file may be bad sectors or head alignment error. therefor remove and pls attach another hard drive temporary and check . pls find the laptop the same specs fpr avoid incompatible files and showing blue screen,
Sep 28, 2017 | Toshiba (M305-S4910) PC Notebook
My dell mini 10 always hang
Mini computers come with 1GB RAM so the system will be slow..
If it freezes very often then try to run a disgnostics on the system.. U can do it by turning on the computer tap F12 - under advanced boot options select diagnostics and run a complete test.. If you get any error codes then contact dell to fix the issue.. If you dont get any error codes then try to clean the computer by doing disk clean up... If it still hangs then do a complete reinstall....
Sep 03, 2010 | Dell Inspiron Mini 10 Notebook
Hi My Laptop is very slow in booting and
Try to run a diagnostic on the hardrive and memory. Dell has a built in diagnostic. to run the built in diagnotic, make sure the laptop is turned off. Hold Fn, then press power button. you will see the diagnostic screen. after running the diagnostic and you didn't see any errors, try to reinstall the Operating System. try to isolate the problem first before replacing the parts. if reinstalling the OS still makes the computer slow, better call Dell tech support.
Feb 23, 2010 | Dell Inspiron 6000 Notebook
Some keys of the keyboard do not work and it works very slow
for some key are not workign you have to replace the hole keyboard, for slow problem it may be the operating system problem or harddisk problem, try to farmat and reload the os first it doesn't give any solution then run diagnostic it may give you the error for harddisk
Jan 10, 2010 | Dell Inspiron 2200 Notebook
Hard drive controller
Certain diags only test the diagnostic tracks. That is what's passing more than likely. You should boot the laptop in safe mode (F8) and click start, run, type in cmd, hit enter and type scandisk. This will do a complete scan on the drive. If there are any errors replace the drive.
Jul 30, 2007 | Compaq Armada 1700 Notebook
Dell Inspiron 8600 Notebook Logo
111 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
