Try:
http://www.excelia-hifi.cz/cambridge-audio/manual/cambridge-audio-azur-550a-650a.pdf
Is the user manual try the OEM for the service manual, most OEMs will require you to be qualified to do the repair.
SOURCE: I need a psu for a Cambridge Audio Azur
any stepdown transformer rated 12V secondary with at least 0.5A rating would do (12V, 500mAmp). I know they said to use only the supplied power unit but hey that's business! but make sure whether your mains supply is 110Vac or 220Vac.
SOURCE: i want to buy a
Cambridge Audio will be the only people that have spares
Check their website
SOURCE: Just set up my brand new cambridge audio azur 650a
Just make certain that the connections are all good with no wires touching. If it still doesn't perform after that return it to where you bought it and get a new replacement or your money back.
SOURCE: C/Audio Azur 640C Cd player rejects discs
Basically have a problem with this CD player design. I have one and I finally realized it was a problem of contact failure on the motherboard to the bus cable coming from the laser head. The head movement is transmitted to the connection point of making it move and fail the connection this phenomenon makes the reader is unable to read the disc. Solution, fix the bus cable head to the chassis of the mechanism of the CD just before the point of connection to the motherboard, making the movement not Transmin connector. He has not failed but for the most beatings I have given to the chassis of the reader.
