Question about Janome Memory Craft MC300E Embroidery-Only Machine By The Each
Mc300 Customizer 10000 how to flip a design from download. once I download I can flip it.The pattern is 100.00mm x 136.00mm but the Customizer will not let me flip so the it is 136.00mm x 100.00mm
Posted by Pat Peters on
Chris Wetmore
    New Friend:
  • 190 Answers
Hello pat this is a function of the hoop size. if the hoop is tall but not wide you cannot flip it. choose a larger hoop
Posted on Dec 29, 2014
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
SOURCE: Attempting to find Janome customizer 10000 plus software
Simply contact your nearest Janome dealer, or the Head office in your country and they will be pleased to assist and outline the options available.
Posted on May 29, 2008
Anonymous
SOURCE: cannot transfer designs from customiser
removed customiser 10000 & installed customiser 10000 plus both programs conflict with each other you can only run 1 program.
Posted on Oct 07, 2008
Anonymous
  • 8 Answers
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
Posted on Jan 11, 2009
Anonymous
  • 8 Answers
SOURCE: Reading Janome design cards with MC 10000
Please sent email [email protected] And we can solve you problem, There is any words i don't understand. If it will be understandly, I can help you. skype - serari55 - my nicke.
paj42
  • 1116 Answers
SOURCE: I just purchased a Janome CM350E and need Customizer software
You can use any machine embroidery software brand.
There are many that have free trials and demos. Embird is one brand that is very popular.
You start with Embird Studio and then add other programs as you become more knowledgeable about machine embroidery.
All ME software products run on Windows XP, Vista and some are now compatible with W7.
You can find more machine embroidery discussions/questions and answers at sewforum.com
Posted on Mar 25, 2010
10000 customizer
Put your card and select touch screen embroidery mood then you can see the designs. Design should be loaded to the card through customizer and CF card size to 1GB or less.
Nov 04, 2013 | Janome Memory Craft 9500 Computerized...
I have memory craft 950.computer crashed and had to relace- now have windows 7 and can not install my cstomiser 10000 plus (ver1.0
There are software updates for the Customizer 10000. See: http://content.janome.com/index.cfm/LearningCenter/Software_Updates . Drivers and installers have changed over time.
I do not know the limitations of the update software.
I hope this helps.
(The other thing to try is the compatibility mode. This may work directly - right click on the installer and choose Properties. Then choose the compatibility tab and set the Program to always run as compatible with XP. Then right click again and choose Run as Administrator. If this doesn't work, another option is to run a second computer with an older version of Windows. You can use a true second computer, a dual boot computer or a virtual computer (which takes a portion of memory from the main computer but doesn't require a restart). If you have Windows 7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. The other options require a valid Windows license for the older OS. Install your Customizer in the older OS as you would normally install the software.)
Mar 10, 2011 | Janome Memory Craft 10000
Mar 25, 2010 | Janome Memory Craft 10000
What is a fat error on a janome 300e
l am having a problem opening in customizer 10000 for my 300e to download designs to flashcard it comes up fat error have tried on another hard drive is the same problem it is not that l havent done this before all has been going ok till now could you please advice me as to what l can do. [email protected]
Sep 13, 2009 | Janome Memory Craft 9500 Computerized...
Jan 07, 2009 | Janome Memory Craft 10000
Oct 06, 2008 | Janome Memory Craft 10000
May 29, 2008 | Janome Memory Craft 10000
Cannot get Janome 10001 to read via USB direct link from computer
You need to have Customizer og Digitizer pro to send design by cable to you MC10001.
You can also use a PCMCIA adapter in your MC10001 and a CF memorycard..you also need a memorycard reader to write to your CF card from your computer
Dec 28, 2007 | Janome Memory Craft 10000
Janome Memory Craft MC300E Embroidery-Only Machine By The Each Logo
57 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
