The bike was being start without using the decompresion lever. The bike would kick over with great difficulty because it would sometimes have that much copression that it was impossible to kick. After it was kicked over without the decompression and started it was riden for a short period then staled out. When trying to restart the bike it still had compression and somtimes and overload of compression, then bike was then dropped and when picked up again it was pushed a short distance then when trying to kick the bike over it had no compression and did not build up and compression at all...?? Could you please give me a few ideas of what you think the problem is, so i can how a look into today to see if it can be fixed or not? Cheers mate, Samuel Bleakley
SOURCE: my 426 is kicking over without the compreshion release lever
I had the same problem on my 01 WR426 just recently after having it transported from Sydney to Perth. Valve clearances were within spec. I removed the head and poured a solvent down the intake and exhaust ports as detailed in the repair manual and found two valves on the intake side and one valve on the exhaust side leaking. After removing the valves I found small carbon deposits on the seats causing the leakage. I relapped them with the fine paste, reinstalled and found they held on both sides. At the same time I checked the rings in accordance with the repair manual and found them outside the standard spec but within tolerance and therefore replaced the rings as a set also (the piston and cylinder were still in spec and original hone marks were still evident on the bore). After replacing the head and the cylinder and installing the spark plug I kicked it over and had the compression back again (I can put my entire bodyweight on the starter and it will not budge at TDC). Hope this helps.
SOURCE: while riding my yz 125 it just died and won,t kick up again
Please rate the solution as a "FixYa" if able. Thanks!
Yes, there is a proper way to start the engine. Four controls are on your bike to assist in starting.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Release the de-compression lever and give a strong kick through the full sweep of the kickstart lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
As to the inability to keep the bike running, Clean the fuel system.
ALWAYS have a fire extinguisher on hand when working on carburetors. Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Be sure the gas cap vent hose is clear and the fuel petcock vent hose is clear. Check to see the fuel flows freely through the petcock.
Drain the carburetor. There should be a large screw on the bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine. At the back top left side of the carb is the TPS, Throttle Position Sensor. Do not remove the TPS from the carb. Rather, disconnect the TPS wire lead from the wiring harness.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the air screw on the outside back throat of the carb and spray into the screw hole as well.
< < READ CLOSELY > >
IMPORTANT > re-install but do not tighten the air screw down. Only screw it inward until it LIGHTLY seats. Now turn the air screw one and one half turns outward. Pay special attention to the pilot jet, aka > idle jet. It is located at the front edge of the carb. Turn the adjuster outward 1/2 turn. Put the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road. I suggest you install an in-line fuel filter between the petcock and carb.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock.
www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
This all sounds complicated, but right now it is a learning process for you. Pretty soon your friends will be asking YOU for advice.
Please top rate this solution. Thanks!
SOURCE: whilst riding at long periods at high speed my
It sounds like you cooked her. If you are jetted lean, and run it wide open for a long period of time, it melts the ring to the piston.
Do a compression test, remove spark plug, thread in gauge, and hold throttle wide open and kick untill the guage stops climbing (Around ten or so) Less than 100 psi is bad.
