My new iPhone 5 will not pair with my sena smh10r motorcycle Bluetooth device. However, my previous iPhone 4 did. I have followed the Sena instructions, however; with the Bluetooth function on it will not pair.
SOURCE: Problem Pairing Blackberry 8700 w/ BlueAnt Z9 Bluetooth Headset
This problem has been solved by turning on the blue ant system then holding down the vol - and vol + buttons simultaneously for 5 secs.
SOURCE: Iphone does not pair with LG HBS-250 Bluetooth Headset
the bluetooth of iphone is not compatible with this.get the bluetooth application installed from itunes store to maki it compatible.
SOURCE: My Jawbone headset will not pair with the iphone
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
SOURCE: Jabra BT135 won't pair with my Iphone -
take the Bluetooth device and keep its button pressed till the light stables that is u will have to hold the button for more then 10 seconds!!! then once the light is stable keep it like that and take the phone and search for Bluetooth devices it will find it now and then enter the pin given in the manual or mostly it is 0000 and pair the two devices now u are ready to use it!
enjoy!
reply and rate!!
Testimonial: "Wow - what a fast answer! Really much appreciated, thank you. I did just as you said and got my bluetooth headset connected straightaway. Once again - thanks for the superfast response"
