Question about Refrigerators
<!-- from fixya rte -->Samsung rl39wbmsNOT WORKING SHOW D5 ERROR - Refrigerators
Posted by Waseem Shafique on
Amol C Nemade
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Contact Samsung Service Center via phone and inform them about D5 Error. They will surely tell you what does that mean.
Posted on Oct 04, 2014
What mean d5?
go to the manufactures website and download the user manual its normally free to download as we don't know what kind of machine you have d5 can mean anything on any machine eric
Dec 27, 2017 | Washing Machines
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
What does d5 error indicate?
A D5 error? Are you sure you're not reading it as "d5"? If you're in the Drive Module, d5 is "distortion+". If you're in the Delay Module, d1-d9 are settings that control the mixing ratio of effect sound versus original sound and the feedback amount. I'd refer to a user manual here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Jun 12, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
When i try to start the washer code d5 shows ands chimes
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Washing Machines
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
Oct 14, 2010 | Samsung WF337AA Front Load Washer
When i turn it on it beeps and the letters d5 show up
hello,
this indication is an error code saying that the door of the washer is not well luck /close
what you are to do to solve the problem is to put off the washer from the power supply then on it again after some time then open then door and close it properly with care the d5 code will be solve
thank you and thanks for using fixya.
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
