Nothing on the upper and lower intake manifold should be loose. It can cause a gas smell. The PCM is over compensating for a bad vacuum leak. Other things can cause gas smells also. Have it scanned , later down the road it will cost you lots more....
The rifle was originally designed by Jonathan Browning, brother of John Browning, but died before the design was completed.
Winchester hired David "Carbine" Williams, who had began design on a "short-stroke" gas piston design, having him finish the M1 design.
Some of the propane units use ammonia as the coolant and not freon. Is the odor you are smelling anything like ammonia? If so you need to check the coils for a leak.
If you post the make and model, I will try to help further.
Hi! Well if the gas is not leaking, Then might be a problem in the Vacuum system or the Map sensor or leaky injector and Mass Air Flow Sensor. All these things can make your engine consume lot of Gas. Check the car for any smoke or any vibration or Gas smell. Good luck
If it smells like rotten eggs, or coal gas, the catylitic converter needs replacing.If engine light comes on after the change 10 to 1 the 02 sensor went bad.
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
