What extent AC do I requirement to cool my chamber?
I have a Honeywell programmable thermostat and a few days ago the "filter" indicator was on the screen.
Posted by Kevin Bella on
Fernando Chavez
    New Friend:
    Problem Solver:
  • 5 Answers
The regular is actually 3500 in order to four thousand Btu's associated with air conditioning have to make up for the quantity of temperature created with a one thousand watts lighting. Instance: ten By one thousand watts lamps will need among thirty-five, 000 as well as forty, 000 Btu's associated with air conditioning. Five By one thousand watts lamps will need among seventeen, five hundred as well as twenty, 000 Btu's associated with air conditioning. They are common recommendations because space circumstances, background air flow temps as well as air flow techniques almost all differ.
Posted on Oct 04, 2014
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
The cooled air is coming out at a very weak rate. The ac unit outside is blowing out cool air when the neighbor's is blowing out warm air. The house is just not getting cool. AC has been on for 4 days...
Turn off your A/C and put your fan switch in ON or FAN. Run the fan only for approx 3 hours. Check your air filter and clean/replace as necessary. Also check your evaporator coil and clean if necessary. It is possible that your evaporator coil is frozen up from a dirty filter or coil. If it continues to be a problem, you probably have a refrigerant problem which will require a certified service technician to address. Try taking care of the filter and coil first. :-)
May 28, 2010 | Honeywell Electronic Programmable...
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
Honeywell CT3600-AC not working
could be froze up if it is turn it off to melt ice clean unit could be low on freon or bad blower motor
Jun 17, 2009 | Honeywell CT3600 7 Day Electronic...
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
Need a "trouble shooting" guide for FocusPRO TH6000
i have the heat set at 73 the temp in the house is getting colder it is at 67 now and it won't come on . why?
Jun 12, 2009 | Honeywell Electronic Programmable...
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
