How do I stop mid cycle and open door. I think it's overfilled or something!
SOURCE: Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
The pump on your washer is apparently not working. It should have pumped the water out when the FL was displayed. You should schedule service and let a technician diagnose and repair the washer.
Flood Condition F L "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
