Question about Carrier Comfort 3.0 Ton 13 Seer Ac Only Unit
Compressor want come on
Power chech good but the ac compressor want come on
aointedu
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Here is what to do . Pull out or turn off Electrical disconnect behind unit . Carefully remove panel covering controls in unit . Note most units have a flat panel with a few screws, but some GE units have a welded metal box on top of unit which needs to be removed. After exposing controls. replace or turn on disconnect. Then take a plastic handled screwdriver and push in on center of contactor (boxlike part with a lot of wires hooked ) If the compressor now comes on release contactor , and check for 24 Volts AC at base of contactor where thermostat (small wires that run on outside of black refrigerant line ) with thermostat on and calling for cool you should measure 24 to 28 volts . If voltage is present replace contactor after disconnecting from power. If no voltage go inside , remove cover from thermostat, and check for 24 volts between red ( R) and yellow (Y ) terminals on thermostat , If voltage is present , replace thermostat , no voltage check voltage in heater / air handler if you have voltage at air handler , replace thermostat wire from heater to thermostat / if no voltage check for blown fuse in heater , this should be either an inline fuse or an automotive type fuse plugged into circuit board (with power to heater disconnected check broken wire or black mark in fuse when held up to light. If fuse good turn on power to heater and check for 230v to one side of transformer, if you get voltage to Primary (incoming side ) of transformer, check output side of transformer for 24 - 28 volts. If transformer shows input but no output replace transformer after turning power off. If you heard a buzzing or grinding noise , when pushing in contactor , but compressor didn't start look at run capacitor (this is round or oval shaped object with wires going to contactor and compressor ) Looking at area where wires plug this should be a flat surface , if it looks domed shaped or bulging out , it is blown and needs replaced , use same mfd rating and 440 Volts to be on safe side. / If there was no noise from compressor when contactor was pushed in , put your hand on top of compressor (black object in center of unit ) If hot , allow to cool for at least three hours with power to unit turned off and retest . If compressor comes on after cooling , check for bad fan motor in outside unit (it may make a squealing or wining noise and stop runing for a while , also check for / clean outdoor coils
Hope this helps .
Thanks,
Alex
Posted on Oct 05, 2014
AC not working on 2001 Mercury Villager
AC will not run unless the clutch is energized. You got it to engage by jumping power line. Check to see if there is a relay in the circuit that gets power to the clutch. 35PSI at 3000 rpm at 75 degrees ambient is about right. How about checking the AC on/off switch? Get a schematic and chech any component in the power trail to the clutch.
Sep 01, 2017 | 2001 Mercury Villager
Compressor not coming on check red wire on compressor with test light compressor comes on pressure good high and low air cold
If the compressor came on when you were testing it with a test light, it sounds like something is wrong with your ground for your compressor, and completely the circuit through your test light.
Jul 01, 2011 | 2003 Honda Civic
I have a 02 lincoln ls . the air conditiong is not working . i took it to a local shop they check the compressor, fuses, relays, pressure swithches, all is checcking out good. They jump the compressor...
YOU COULD HAVE OPEN OR SHORT IN THE BLACK YELLOW WIRE GOING TO AC COMPRESSOR CYCLING PRESSURE SWITCH. CHECK FOR A SHORT OR OPEN IN RED YELLOW WIRES AT THE AC PRESSURE CUTOFF SWITCH. USE VOLT METER AND CHECK FOR VOLTAGE AT BOTH SWITCHES. PROBLEM COULD BE IN THE EATC MODULE THAT SEND POWER TO PURPLE WIRE THAT FEEDS THE AC PRESSURE CUTOFF SWITCH AND AC CLUTCH CYCLING PRESSURE SWITCH THEN FEEDS THE AC COMPRESSOR CLUTCH SOLENOID.
Jun 24, 2011 | 2002 Lincoln LS
Have no power to the ac compressor. all fuses and
SOUND LIKE AC COMPRESSOR CLUTCH COIL IS OPEN.ITS GETTING POWER YOU HAVE A OPEN COIL CIRCUIT.
May 27, 2010 | 2002 GMC Yukon Denali
I have split ac samsung,which has problem with no cooling.. also voltage flactuate when ac start i.e. from 240 to 188.. plz help
my friend us hould check your aircon have proper gas and may be there is a problem in your compressor u should chech power current supply of air con its possible there is aircon have short gas problem so contect to your a.c technician for further action.
Apr 25, 2010 | Samsung AW0603B Air Conditioner
1997 pyzar 1.5 ac full of gas but ac wont work
CHECK AC COMPRESSOR CLUTCH SHOULD BE ENGAGED OR RUNNING WITH AC SWITCH ON POSITION.IF NOT CHECK AC COMPRESSOR CLUTCH FUSE AND RELAY.IF BOTH GOOD AND POWER IS GOING TO AC CLUTCH.YOUR CLUTCH IS OPEN.IF ALL LOOKS GOOD YOUR AC LOW PRESSURE SWITCH IS BAD.COMPRESSOR SEIZED OR YOU HAVE TOO MUCH MOISTURE IN AC SYSTEM.
Mar 10, 2010 | 1991 Daihatsu Charade
AC, CHECHS OK BUT BLOWS HOT AIR
HI WHAT YOU NED TO DO IS MAKE SORE THE COMPRESSOR IS RUNING WEN YOU TURN THE AC ON IF DOESN'T ENGAGE THE MEANS THE AC IS LOW IN REFRIGERANT
Jul 26, 2009 | 2004 Lincoln LS
2003 hvac blowas hot air and compressor wont come
you havea broken cable to the vent blend motor or a bad vachum motor.
Jun 22, 2009 | 2003 Chevrolet Impala
Carrier Comfort 3.0 Ton 13 Seer Ac Only Unit Logo
131 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
shizznat
Level 1 Expert
jdthefixer
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
