Sony VAIO Notebook Logo
A
Anonymous Posted on Oct 04, 2014
I can't open my Microsoft word, because the dialog box is open
How to find an open dialog box and close it?
You can hold down your Alt key and repeatedly press the Tab key to cycle through all the open windows until you find tie dialog box; or you can minimize each Window you have open until you find it. Then click on one of the dialog box's choices, or the X in the upper right to close it.
tip
Protecting your documents with password !!
You can protect your document by applying password so that unauthorized person can not display as well as modify your document. You can apply two types of passwords:
Password to open the document:
If it is applied then you have to give the correct password to open the document, otherwise you cannot open the document.
Password to modify the document:
If it is applied then you have to give the correct password to modify the document, otherwise your document is opened but you cannot modify the document. It means that your document becomes read-only.
To apply a password to document, follow these steps.
* Open Save As dialog box by selecting "Save As" command from File menu.
* Click "Tools" button of Save As dialog box and choose "General Options" from drop down menu, "Save" dialog box appears as shown in figure below.
* Enter first password in "Password to open" text box and second password in "Password to modify" text box (if required) and click "Ok" button of dialog box. Microsoft Word will open "Confirm Password" dialog box for the confirmation of passwords. The maximum length of password is 15 characters.
* Re-enter the password to open and password to modify and click "Ok" button of Confirm Password dialog boxes one by one.
* Click "Save" button of Save As dialog box.
on Mar 19, 2010 • Computers & Internet
tip
Protecting Document with Password
on Jan 29, 2010 • Computers & Internet
I cant open attatchments to email. A box that says it cant perform the action because dialog box is open pops up. I don't know what a dialog box is.
Please download the attachment from the E-mail and then open the downloaded file, if the issue persists. Please uninstall and re-install the Microsoft Office. If you are worried about purchasing Microsoft Office, you can download and install the Open Source freely available OpenOffice which can be used to read and write Microsoft Documents like Word, Excel...etc from the below link :
http://www.openoffice.org/
Hi, I've just installed Microsoft Office Publisher 2010 on my PC (Vista Basic). It works fine and everything. However the saved publisher files have icons like blank pages and won't open automatically...
Hello:
You can manually locate Microsoft Publisher when going to the "open with" dialog. Follow the steps below:
  1. Right click on a Publisher file.
  2. Choose "Open With..."
  3. Choose "Choose Default Program..."
  4. A dialog box will open. There is a list of programs at the top.
  5. Near the bottom of the dialog box, there should be a link that says "Browse..." Click it.
  6. You need to locate the Microsoft Publisher Program. For Office 2010, it should be at:
x86: C:\Program Files\Microsoft Office\Office 14\MSPUB.exe
x64: C:\Program FIles (x86)\Microsoft Office\Office 14\MSPUB.exe
7. Click once on the file and choose "Open" 8. Check the box called "Always use the selected program to open this kind of file" 9. Confirm your selections and click "OK" at the bottom of the dialog box.
tip
Add Specific Folders to the Open Dialog Box
When you use certain Windows applications (such as Notepad) to open a file, on the left side of the Open dialog box are a group of icons and folders (such as My Documents, My Recent Documents, Desktop, My Computer, and My Network) to which you can navigate to open files.
Good idea, bad implementation. Do you really keep documents in My Computer? Unlikely, at best. It would be much more helpful if you could list only those folders that you use, and if you could choose to put any folder there, not just ones XP decides you need.
In fact, you can do it, with a Registry hack. It'll let you put just the folders of your choosing on the left side of the Open dialog box. Note that when you do this, it will affect XP applications such as Notepad and Paint that use the Open and Save common dialog boxes. However, it won't affect Microsoft Office applications and other applications that don't use the common dialog boxes.
TIP: If you want to change the dialog "frequently used" folders for Microsoft Word, try Woody Leonhard's Place Bar Customizer, one of many useful utilities from http://www.wopr.com/.
Run the Registry Editor and go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\comdlg32. This is the key that determines how common dialog boxes are handled. You're going to create a subkey that will create a customized location for the folders, and then give that subkey a series of values, each of which will define a folder location.
To start, create a new subkey underneath HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\comdlg32 called Placesbar, and create a String value for it named Place0. Give Place0 a value of the topmost folder that you want to appear on the Open dialog box-e.g., C:\Projects.
Next, create another String value for Placesbar called Place1. Give it a value of the second folder that you want to appear on the Open dialog box. You can put up to five icons on the Open dialog box, so create new String values up to Place4 and give them values as outlined in the previous steps. When you're done, exit the Registry. You won't have to reboot for the changes to take effect
If you want no folders to appear in common open dialog boxes, you can do that as well. In HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\comdlg32 create a new DWORD value called NoPlacesBar and give it a value of 1. Exit the Registry. If you want the folders back, either delete NoPlacesBar or give it a value of 0.
Turn Off System Beeps
To me, system beeps that my PC makes when it encounters certain system errors are like balloon tips-gnat-like annoyances that I can do without. So I turn them off using a Registry hack. Run the Registry Editor, go to HKEY_CURRENT_USER\Control Panel\Sound, and find the Beep and ExtendedSounds String values. Set each value to No. Exit the Registry and reboot. The beeps will no longer sound.
1helpful
Unable to open a saved doc in word because of open dialog box.
may be it is asking for the serial no. kindly install the serial no and use the application.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
3helpful
Troubleshooting MS Word 2003 XP
Hold down your ALT key, and touch the TAB key.
You'll see a list of "open" windows.
Touch the TAB key again, and the "outline" rectangle around one item in the list will move to the next item.
Release the ALT key to "focus" on the window.
If it is a "dialog" window (with 'yes' or 'no' or 'cancel' buttons),
close the window.
Repeat the hold-down-the-ALT-and-touch-TAB until you have closed the "dialog" window that is "blocking" Word.
98helpful
5answers
How to close dialog box to open microsoft word office
im having the same problem!!!! im trying to finish my paper for my geograhy class. but theres a pop up that wont let me for to my work tht i've already done...its telling me to vlivk ok, and then close open dialoge boxes to continue! WHAT DO I DO?????
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
