Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Vacuum stopped working as I was vacuuming
You can purchase replacement parts directly from Govacuum with an exclusive 11% discount for Fixya.com readers, use code: FIXYA11 at checkout for 11% discount. We also offer free shipping over $35.
Hoover Windtunnel Upright Belt 38528034 - https://www.govacuum.com/products/hoover-windtunnel-upright-v-p-d-belt-1-only-part-38528034
Hoover Type Y bags from ZVac - https://www.govacuum.com/products/15-hoover-windtunnel-hepa-style-cloth-type-y-vacuum-bags-allergen-filtration-with-closure-similar-to-hoover-part-4010100y-4010801y-and-43655082-by-zvac
Hoover Exhaust Filter AH45004 - https://www.govacuum.com/products/hoover-u5750-u5760-wind-tunnel-bagless-upright-exhaust-filter-2-pack-genuine-part-ah45004-40110006-38766021
Hoover Parts - https://www.govacuum.com/collections/hoover
Jeethu
Govacuum Team
Posted on Sep 17, 2017
Hi, it's Allie from Crucial Vacuum!
Your Hoover Windtunnel may have stopped working for several reasons. First, make sure that your unit is properly plugged into an electrical outlet and make sure the electrical outlet is working correctly. Vacuum units, and other appliances, protect themselves from sudden electrical charges, ups and downs. Make sure the electrical fuse and breaker are on, if not reset breaker.
Some units may heat up and will automatically shut themselves down to prevent fires. Allow your unit to cool down for 30 minutes while the thermal protector is automatically reset. Overheating, may have been caused by a clogged hose, dirty filters, full bags or a roller brush that is not running properly. All these situations compromise the unit's air flow and make the unit work harder, making it to heat up.
To avoid these situations and to keep your unit running at it's maximum capacity, make sure to change filters regularly (recommended every 3-6 months), clean your brush roll from any tangled hair strands or debris monthly (roller brushes are recommended to be replaced at least yearly), and replace belts every 6 months.
You can purchase direct your replacement belts, bags, roller brush and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-windtunnel-self-propelled-roller-belts.html
http://www.crucialvacuum.com/vacuum-bags/hoover-type-y-paper-bags-18pk.html
http://www.crucialvacuum.com/hoover-40110006-three-layer-final-filter-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Posted on Oct 06, 2014
SOURCE: How to change a belt
A very easy procedure!
Look at the front hood of the Purepower (where all the lettering is including the 1600 or whatever the model number and name is located at) and you'll see at the back two screws either side where the back wheels are. Unscrew these and then prise using your hand/fingers the floor selector dial knob off. Once that's done the hood will pop off and you can get into the roller brush and drive belt. Then simply lift out the roller brush and fit a new belt.
This method is for all Hoover Purepower models and DustManager uprights.
Posted on Sep 27, 2008
SOURCE: my hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Posted on Dec 02, 2008
SOURCE: carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 17, 2009
SOURCE: I was vacuuming and my hoover vacuum died
they have a thermal shut off on the motor so if it gets too hot it shuts down
can take up o 30 min to reset check all filters make sure nothing is blocking
Posted on Aug 17, 2009
SOURCE: my vacuum has stopped working and shut off in the
no power, plugged/jammed impeller. some newer ones have a sensor that turns it off when it is full of dirt...
Posted on Nov 09, 2009
Jun 17, 2012 | Vacuums
Mar 11, 2011 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Jun 05, 2010 | Miele S143 Bagged Upright Vacuum
Apr 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Sep 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Sep 12, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Jul 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Jul 02, 2008 | Vacuums
Jun 30, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
1,191 people viewed this question
If NOTHING is working on the vacuum cleaner, it has had time to cool off and still doesn't work, make sure the outlet has power, then check the power switch. It is not too difficult to change one if you are handy with tools. You must check what the part number for your particular model is, but our old wind tunnel Had a switch fail. Ours went bad after 15 years of use. CW Industries 16A Part GRS-2011-2019 worked on ours. It was on Amazon.com The wires had two pull off insulated brass connectors. There are videos on YouTube showing how to replace it.
