EITHER OT HAS BEEN MOVED RECENTLY AND THE FRAME MAY BE SLIGHTLY TWISTED . IF THE DRAW HAS BEEN REMOVED IT MAY NOT HAVE LOCKED INTO THE SLIDES CORRECTLY ?
MAKE SURE THE DD IS LEVEL AND FREE FROM ANY MOVEMENT . THE FRONT COVER HASNT COME AWAY
IF THIS DOESNT WORK UNHOOK THE DRAW FROM ITS ROLLERS AND MAKE SURE THE TABS AT THE VERY REAR OF EACH IS PULLED FORWAED BEFORE REFITTING THE DRAW TO ALLOW IT TO ENGAGE EVENLY
I HOPE THIS HELPS
SOURCE: red light flahing on right hand side of contols on the door
If it's the model I'm thinking of that can just be a blip in the software or it means the heater isn't working. I assume it's flshing 7 times? Press heated dry then skip a button to the right and press the next one then back to heated dry back to the last button and do that a toal of three times. All the lights should come on wait about 30 seconds and press cancel. It should make that error go away. If it comes on again during the next cycle it's probably a problem with the heater. Clearing it out at least you can use it. I don't remember the exact buttons to do that special code becuase I just know the sequence by heart but there should also be instructions on how to do it on a tech sheet that's under the bottom panel if you take it off. Good luck. Let me know how it works out for you!
SOURCE: MDB9600A Jetclean II Built-in Dishwasher: leaking around door right side bottom...
Hi, fd
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
