Tuneing mogilation
SOURCE: non grnd steel antena
I assume your coax is not hooked up properly or you have some kink of a short in your antenna connection ( thats if your cb is working properly ) Radio Shacks Information that suggested that the 102" whip is the perfect antenna is their opion only as I prefer to recommend a full wave antenna system to my customers, but I do assure you, the 102" whip does work well if it's properly installed. I have found the main problem in the 102" whip installation is when the center hole is cut to install the antenna, it's not cut big enough, which grounds the antenna. It's not suppose to be grounded in any fashion to the automible chassis. The ground of this antenna comes from the 3 screws mounted around the outside of the antenna mount. Check that for sure. If you can't correct the problem. write me back at this web sight of direct at [email protected]. Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: peak tune
I need the tx meter on a galaxy saturn,can you find one for me.ùthank you very much
