Question about Apple iPhone Smartphone
<!-- from fixya rte -->How to change ring tone on iphone 5c - Apple iPhone Smartphone
  • Silver Paris Dec 09, 2019
    Hi, 1: go to settings 2: slide to sounds and vibration and click ringtone! Or you can search and download various music, or use the music directly on iPone and itunes!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
If you want to change the ringtone on your iPhone, the steps as below will help you to perform this task in an easy way.
1. Tap on "Settings" on the home screen of your iPhone. Then choose the option "Sounds & Haptics".
2. Tap on "Ringtone" in the section of Sounds and Vibration Patterns. Multiple ringtones can be found in the list and you also can see the current ringtone which is being used.
3. In this "Ringtone" screen, all ringtones on your iPhone can be seen here, you can select the ringtone you like whatever the default ringtone or the purchased ringtone or the custom ringtone.
4. You will see Alert Tones when sliding down the screen of your iPhone, Alert Tones are usually applicable to alarms or other notification, but they can also be applied to ringtones as well.
5. You can preview the ringtones that you have chosen, as the ringtone will play once you tap on it, then you can determine whether this ringtone suits your need.
6. Once you have selected the ringtone as default for iPhone, the checkmark beside the ringtone must exist and then you can go away from this screen, then tap on "Sounds & Haptics in the previous screen. Finally, your selected ringtone will be saved automatically.
After that, the ringtone you just set will play when you receive a call.
check more information pls turn to How to Add Ringtones to iPhone
Posted on Dec 03, 2019
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
By going to settings and then sounds. But first you need to buy some ringtones or make some in itunes using instructions here.
http://www.idownloadblog.com/2013/05/16/how-to-create-ringtones-in-itunes/
Posted on Oct 09, 2014
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 19 Answers
SOURCE: Can you use your music as a ring tone? I can't figure it out
APPLE has actually disabled that! but Im sure they let you buy them
Posted on Aug 03, 2007
janderson239
  • 10 Answers
SOURCE: how can i change the ringing tone of my iphone?
You can use the ringtones stored in Settings > Sounds > Ringtones. Otherwise, you can purchase custom ringtones from the iTunes Store application. You can also try using 3rd party applications that are named ringtone makers and try to use music in your iPod application. You cannot set songs in iPod as ringtones directly.
Posted on Feb 28, 2011
How do I change iPhone ringtone?
For more detail, check: How to Add Ringtones to iPhone
Mar 06, 2018 | Computers & Internet
How can I retrieve my caller tunes from iCloud after a restore on a(n) iPhone 6 plus?
I have read of others having same problem of missing tones after restore or upgrade. Fwiw - I always save backups of everything on my iphone to my PC using iTunes and only use iCloud as my secondary backup. Using iTunes allows selection of each category including "tones". Even though the tones were restored, I found that each contact was reset back to default. I had to go back to each contact, select "edit" and then select "ringtone" which brought up the listing of available tones and all my custom tones were at the top of the list.
if you purchased ringtones or downloaded free ring tones from the iTunes Store and they are missing, you should be able to go to the iTunes Store on your iPhone, select "more" then select "purchases" and re-download them, they may only be listed under the music category. Although I also have heard some people are missing ring tones from their purchases. In this case, you will need to email or call apple customer service.
if all this fails, your can use iTunes or any other music editor to make your own ring tones. Basically you save a copy of the song in m4a format, edit the start and stop times to be 30 sec max play time and save the clip as an .m4r file. You can google the procedure, it's fairly easy. In iTunes, save the clip with a new title then go to the actual file location on the hard drive and simply change the file extension to m4r, then add the file to iTunes and it will show up under "tones", repeat as desired then you can sync the tones.
without iTunes, you need to use an app to make ring tones on your iPhone - Apple has not yet provided this functionality.
Mar 05, 2016 | Apple - iPhone 6 Plus 16GB
How to change from iphone5c to iphone
Send file to laptop then copy to new sims and install .
Mar 16, 2015 | iPhone 5c Cell Phones
My iphone 5c will not ring how do I turn the ring ton me back on?
on the left side on the phone, theres a switch, turn it on
Oct 11, 2014 | Cell Phones
My phone says its on headphones when its not.how do i fix it so i can hear the messages and ring tone.
Look in the mini jack port on the phone & make sure there is nothing stuck in the port.
Sep 29, 2014 | Apple iPhone 5c
I replaced my screen on iPhone 5c and now I am having problems with the phone freezing and basically having a mind of its own what could be wrong
Some troubles appears along with Apple releasing iPhone 6 and iPhone 6 plus.
I can't play HD AVCHD movies on iPhone 6/6 Plus. This is kinda embarrassing.
But soon, I get a solution - Aunsoft Video Converter.
http://www.aunsoft.com/video-converter-mac/
Sep 14, 2014 | Apple iPhone 5c
How's the new Apple iPhone 5C different from the iPhone 5?
The new Apple iPhone 5C is very similar to the iPhone 5 both in software and hardware. The real difference between the two is their appearance.
Differently from the older iPhones 4s and 5, and the newer iPhone 5S, made of alluminium and glass, the iPhone 5C has an outside structure of polycarbonate, which makes the phone more resistant and similar to other plastic-based phones. Another big change was the color range. The iPhone 5C comes in 5 different very bright colors, only seen on iPods before.
Sep 11, 2013 | Apple iPhone 5c
How do i set a ring tone from a web site on my iphone?
Go here and download this App.
www.iringer.net
you can use ANY song and create your ring tones here then sync the new ring tones using itunes FOR FREE!!!
Sep 29, 2009 | Apple iPhone 3G Black Smartphone
No sound on receiver or keypad after using Bluetooth in car
you should take it to a mobile shop and have them reinstalled the device for you.
Dec 22, 2008 | Motorola Mobility RAZR V3
Apple iPhone Smartphone Logo
104 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
