Maytag Neptune MAH6500A Front Load Washer Logo
Question about Maytag Neptune MAH6500A Front Load Washer
M maytag neptune will not fill. For the last two days, a nd code has come on, now after the last load ran fine, the washer will not fill. We have done all the steps like cleaning the screens. Any sugg
M maytag neptune will not fill. For the last two days, a nd code has come on, now after the last load ran fine, the washer will not fill. We have done all the steps like cleaning the screens. Any suggestions?
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Beeping Neptune washer...
Replace control board
Posted on May 25, 2008
Anonymous
SOURCE: maytag neptune washer code nd,
nd means not draining. u may to check the plastic drain pipe in back to back sure it doesnt have a kink in it, and that it is placed so that the pump inside the washing machine doesn't have to pump it too far to get to the drain.
Posted on Sep 29, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Posted on Oct 12, 2008
Anonymous
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
Anonymous
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
NF code may tag neptune front loader!
www.fixya.com > ... > Neptune > Maytag Neptune MAH5500B Front Load Washer
Apr 14, 2009 - CODE IN MAYTAG WASHING MACHINE Hello & Welcome to FixYa NF error in yourMaytag is displayed due to no fill condition, when the washer tries to fill but ... SOLVED: Maytag Neptune MAH6500AWW '03 front ...
Nov 9, 2016
SOLVED: HOW TO FIX NF CODE IN MAYTAG ...
Oct 2, 2011
SOLVED: Machine is flashing nF code
Jul 13, 2011
Maytag Neptune MAH9700 Front Load Washer Nf code ...
Jun 21, 2011
More results from www.fixya.com
1helpful
I am getting code nd on my maytag neptune washer. how can i fix?
ND code is "no drain" the washer probably has a drain plug/filter on the main pump, more than likely all you need to do is clear debris from the pump.
1helpful
Does not seem to drain completely - ran very long today and the last code I saw was "nd" - not draining? or not done?
nd code indicates a problem with draining. The problem could be:
1. Clog in the drain hose - 2. Drain pump in the washer needs replacement 3. Clog in your sewage
Some simple things to try out
a. Run a wet/dry shop vac at the end of the drain hose to clear out any crud/cloth debris. b. Replace the drain hose altogether (will require a bit of work). Remove the back panel (small) that holds the drain hose in place and disconnect the clamp that connects to the drain hose to thepump outlet. The whole drain hose can be purchased for under $20 at your local hardware store...
Good Luck!
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
1helpful
How do i fix nd code for mde5500ayw maytag neptune
There are two possible causes to the "nd" code. The first is with the pump itself. Either is is blocked or it is simply worn out and needs replacing. The second is a malfunction with the control board. Unless you find a blockage to the pump there is no way to know which one is the cause of the "nd" code without some testing or replace these items.
If you are unafraid of facing your washer with tools in hand then you should be able to test the pump. As for the board, all you can do is check it for damage most likely caused from a component melt down. In which case it's going to need replacement.
But check for blockages first because that will cause the "nd" code.
I hope this helps and good luck.
1helpful
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
1helpful
2answers
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Top Maytag Washing Machines Experts
Robert
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
