Question about Bose Wave Radio
Bose Wave Radio AWR1 1W. 9vOLT BATTERY ran down.
Bose Wave Radio AWR1 1W. 9 vOLT BATTERY ran down. replaced it and now the display has all pixels lit and the radio will not turn on. Tried the BOSE web site suggestion of unplugging the radio for a few minutes to let it reset. Nothing changed. Appears this is a common issue. Is there some additional reset or keystroke sequence to fix it??? Thanks
Posted by nollers on
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: no power up
Considering that power is present, popping sound is caused by a faulty Q401, 5V supply for display.
Good Luck.
Posted on Jan 03, 2008
Anonymous
SOURCE: Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Posted on Jan 09, 2009
Anonymous
SOURCE: My Bose Wave Radio, Model AWR1-1W, has no sound
I found a solution on a similar problem saying the audio amp IC is damaged. You will probably need to replace this. Unfortunately I don't know which IC it is.
Posted on Apr 30, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
Asif Mohamed
SOURCE: Need owner's manual for Bose Wave Radio Model AWR1-1W
i can email a copy of the manual for you, for $5.
Posted on Nov 02, 2010
My bose wave radio won't turn on at all. replaced 9 volt battery.
open unit up and check A/C FUSE located near where the A/C plug/wire is connected to radio!
If fuse is bad it will measure an OPEN ]---- ----[
a GOOD FUSE will measure a SHORT ]-----------[
gl
May 19, 2010 | Bose Wave Radio
Bose radio will not turn on
You didn't mention which model of the Wave Radio you have but since you have a 9V battery it narrows it down to a couple of models. You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
I have a very old Bose clock radio (model AWR1-1W) that has suddenly deceided to light up every single character on the display solidly. Unpluging and plugging it back in does not help. Any ideas?!?...
Hey Pete! Did you take out the 9V battery as well and let power down to re-set? Benimur from JustAnswer suggested: Your described problem could either be a system glitch, hardware fault.
If it were a glitch, unplug the unit for an extended period of time to force the Bose to reset and revert to factory defaults. This would also require removal of the 9 volts battery. Should this be not corrective, then it would seem that the logic circuitry of the Bose radio is faulty. The logic circuitry includes the micro processor that handles all the controls and the displays. Unfortunately, not a user doable repair.
Nov 09, 2009 | Bose Wave Radio
Every light on my bose wave radio is lit up. How can I reset it
Contact Bose at Bose.com. They will have you send it in for repair.
Aug 28, 2009 | Bose Wave Radio
Bill B.
Mar 26, 2009 | Bose Wave Radio
Bose wave radio
phoned bose as i have similar prob, bose said remove the 9 volt batt under base leave for ten mins then plug into mains without bat and try again if this fails it needs to go to bose.
Nov 10, 2008 | Bose Wave Radio
Bose radio won't turn on
My Bose wave radio (w/cd ) was purchased in 1999, it was working fine untill it quit. Power is gone. What could be the cause and how could i fix it or can it still be fixed?
May 03, 2008 | Bose Wave Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Bose Wave Radio Logo
300 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
