Question about Epson WorkForce 600 All-In-One InkJet Printer
I just replaced all four ink colors in my Epson 600 workforce and its not printing right. its all yellow and pink.
Why my color printer is not printing right. Its all yellow and pink
Frank Woodcock
    New Friend:
    Problem Solver:
  • 10 Answers
It appears that some ink nozzles are blocked or not seated properly.
Go to the Epson support site below and enter Epson WorkForce 600 as your model. Then go to Troubleshooting Guide in the list on the right of the web page
Welcome to Epson Support
Posted on Oct 09, 2014
5 Related Answers
gwbm
Gerry Millward
  • 353 Answers
SOURCE: I recently installed new black ink cartridge.
Hi maryryherd - yes the C64 is in the list - don't know why you couldn't see it.
The inkjet colour system can be quite confusing. The colours in the cartridges are cyan, magenta and yellow, plus black. Other colours require a mixture of these basic ones. For example, to produce "red" requires a mixture of magenta and yellow. Your problem sounds like you are getting insufficient yellow, and maybe insufficient black.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are all the 3 colour bands plus black printed OK. If not, try up to three cleaning cycles. If ink is now flowing pretty well, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Posted on Apr 22, 2009
Anonymous
SOURCE: While replacing ink in my Epson Workforce 600, I
Unplug it then hold on button when you plug it back in, Good Luck mine is not a good printer...scanner wont work!
Posted on Mar 01, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: When I do a nozzel check the black ink on my Epson
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
mama cheryl
SOURCE: I have a 600 workforce
my printer is not priting right . it prints a fade shade the colors are blurr
Posted on Mar 18, 2011
SOURCE: I have a Epson Workforce
Hello Jaasp,
Follow these steps to print the nozzle check:
  1. Load a few sheets of plain paper in the sheet feeder.
  2. Press the Home button.
  3. Press cp_button_41_er.gif or cp_button_42_er.gif to select Setup.
  5. Press OK.
  6. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance, then press OK. You see this screen:
  8. Select Nozzle Check, and press OK.
  10. Press cp_button_6.gif Start to print the nozzle check.
  11. Shown below are some examples of what the nozzle check may look like.
    Nozzle check pattern with no gaps
    Nozzle check pattern with gaps
  12. Press Finish Nozzle Check and press OK when you're done.
Posted on Jun 18, 2011
Red and yellow not printing
Red and yellow reservoir have dried up and won't allow ink to flow, clean entire area with rubbing alcohol, let dry and try with new ink cartridges.
Make sure your printer is in a cool location, if it is in a closed cabinet with the computer running the print ink will get baked inside of the printer rendering it useless and replaceable.
May 21, 2016 | Epson WorkForce WF-3540 Wireless...
My Epson Workforce 1100 suddenly stopped printing black when printing in color. This happens when printing from Microsoft Word, Wordpad, Lightbox (photo manipulation) and Adobe Reader. It prints black...
normally most printers even like mine an epson NX110 will use color then black when using text but with grayscale only your forcing it to use black ink more and no color ink set in normal mode some color ink does get used ironically but it is normal for it to use color some as it reserves the black ink being used
Apr 22, 2017 | Epson WorkForce 1100 Wide-Format Color...
Epson Workforce 600 not recognizing black toner
I had the same problem and was told by the store that sold it to me that some printer manufacturers do this on purpose as they make their most money on the ink they sell not the printer. I got rid of mine and purchased an ink jet black only printer as this is all I need anyway. A lot cheaper to use.
Jun 12, 2017 | Office Equipment & Supplies
When I Print the color Yellow, it's being printed as Pink.
I think you switched the ink stations. Try to switch the yellow and magenta. It also is a possibility that they are refilled with the wrong ink color. Place new ink cartridges and your problem is solved! (It can be that a few prints still show some pink color, because there is a residu of magenta in the yellow printhead)
Jul 07, 2011 | Epson Stylus Photo R220 InkJet Printer
Hi i am having a epson t13 color printer but it is not printing pink color what may be the problem please anybody can help me
Hi
This normal with epson printers. The nozzles get blocked and some colors are not printed. Try to take the Nozzles print by Turning on the printer while pressing the ink replace button.
The printer will print a page with some lines, see if you can find all the colors. Cyan Magenta, Yellow & Black lines. if not hold the ink button for 5 sec., and it will clean the head try the 1st step again.
DO RATE MY SOLUTION
Regards,
Saleem
Jul 06, 2011 | Epson Office Equipment & Supplies
I have a Epson Workforce 600 printer. Changed all ink cartridges and cannot get the black ink to print. It will print in color mode only without the black ink. What should I do? Sandy
Hello Jaasp,
  5. Press OK.
Jun 18, 2011 | Epson WorkForce 600 All-In-One InkJet...
I just replaced my ink cartridges for my Epson Workforce 600 printer and the magenta and yellow colors do not print. The status shows that both are still full of ink, but when I do the nozzle check,...
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Aug 07, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Epson WorkForce 600 All-In-One InkJet Printer Logo
359 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
