Question about Bunn 10 Cup Home Coffee Brewer
How do I stop water leak
About it started leaking month ago.we also just started usseing hard water, how do you clean the inside of the tank.
RJ Keck
    Novelist:
    Scholar:
  • 166 Answers
If you're talking about the model shown in your picture, the leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Posted on Nov 23, 2014
1 Related Answer
atbsmmom
  • 189 Answers
SOURCE: leaking from top of water tank
It sounds like a broken seal/gasket. If you will get the model and date code and contact customer service, we will be able to properly assist you in resolving this problem. The machine carries a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced cost.
Posted on May 19, 2010
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
Dehumidifier leaking
I have a duracraft DD-TEC16E I have had this for 12 months and has been working perfectly until today , I have noticed the water is not all collecting in the tank it's leaking on the floor . Any possible solution please?
Feb 14, 2014 | Dehumidifiers
What could be wrong with my 99 Mazda Protege now? 5 months ago it overheated, replace alternator and belt, now battery wont hold charge and is overheating again, and loosing water coolant.
For a coolant leak you need to check all the hoses and fittings by radiator, heater core, expansion tank for leaks and/or integrity. Also make sure that your water pump is not leaking along with radiator cap and thermostat body. Overheat condition has no effect on battery - if it does not hld charge it is because it is chemically worn out and needs replacement. Until you correct water loss, have extra water in car at all times and run your heater full blast - windows open!!!!
Sep 05, 2017 | 1999 Mazda Protege
Car is using water
Better have it checked for a possible headgasket leak. This can destroy an engine!!! (They can leak coolant into the engine oil)
Oct 01, 2009 | 2004 Nissan XTerra
A month ago my a/c started to leak water.We called help & they pumped the tubes then they put freon,they said the leak is on the unit not inside the house,it worked for a week then the a/c stopped...
Could be leak on your indoor coil and they missed it. Call them back ask them to leak check inside. If they missed it it is their rsponsibility. to repair. Rus
Jul 19, 2009 | Heating & Cooling
Leaking antifreeze on the right side new water pump and hose to on over a month ago
you changed the water water pump because it probably overheated. you might have a broken head gasket and combustion pressure is entering the cooling system
May 21, 2009 | 1995 Ford Windstar
Coolant leak and overheating
its hardly one of the frost plugs leaking at the back of the engine is it...due to the pressure when the thermostat stoped working,,,probably a long shot though,,,,
Apr 21, 2009 | 1997 BMW 7 Series
Water leaking from top of expansion tank.
have you replaced the bleeder screws? and the expansion tank cap they both have O-rings that compress and will fail over time also check the hose at the top of the exp tank it also has o-rings inside it
Apr 03, 2009 | 2000 BMW 3 Series
CONSTANT LEAK PROBLEM How can we stop the coffeemaker from leaking? Our coffeemaker is 6 months old. Three days ago it developed the problem of the coffee constantly leaking through the normal dispense...
Try using straight vinger through the complete cycle then run plain water through the cycle see if that helps. It helps to clean the machine.
Jul 22, 2007 | Cuisinart DCC-2000
Bunn 10 Cup Home Coffee Brewer Logo
245 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
